Main > Main Forum
Soul calibur cab *updated* abandoned.
Pages: << < (3/3)
Yenome:
So I grew a pair of balls and decided to just go ahead and discharge the tv so i could do some work on getting it in the cab. after a heart pounding discharge to which nothing happened. I broke 3/4 the plastic from the tv casing as i was aiming for a simular look to malenko tv mod. tho i wish i could just make my own open frame for this tv that would make it easier to put in the cab. I dont have any pics today as its early and im tired. One thing i did want to make note of was when i took the back off this tv there was a 10pin(or so) white connector on the board right behind where it said pc on the back. it looke like the RGB connector on an arcade PCB. a lil research shows that the bigger models of my tv has dvi connectors. im guessing that is what this is for if not it would be awesome if i could just use a vga to rgb connecter and bam multisync monitor.(yes i know im dreaiming leave me to my dreams) ill have pics of it all tomorrow gonna see if a buddy has the tools i need to cut the rest of the plastic away and see bout a good way to mount the tv.
Malenko:
I used a dremel and a hacksaw, lookin forward to pix!
Yenome:
I know i said a few days ago I would have pics up but the PCB in the cab messed up so i had to spend a day fixing it. here two cabinet pics of the tv in place but i didnt bolt it down yet as i was too tired already fell sleep twice. I did all the modding of the case with a screw driver and a pair of pliers cause I'm awesome like that or something. Since i dont have the remote to fix the major overscan the tv has i got a lil converter box that helps with overscan. it supports up to 1280x1024 tho i think ill stick with 640x480. wont be 480p but when i buy the remote ill be able ot make my adjustments and remove the box from the loop. I now have to find a new place to mount the mobo tray i took out of a pc since i was mounting it agaist the back wall that the tv is now barely clearing. think i might just slap it on the side in the bottom so ill have some room to work on it if i need to. tho i plan on building a new control panel if i do keep this cab. Personally I would prefer to not have to reach through the coindoor to latch the control panel. I still havnt decided if i want to wire up the coin door or not. if i do i will either make it so putting in a quarter does what it should or ill just make the coin return register a coin.
Yenome:
So i ordered a xin mo from GGG. just waiting on it to arrive to replace the keyboard hack i have in the cab ATM. Pics to follow once It gets in.
Yenome:
Picked up a smart power surge from walmart for less then 20. also ordered the oem remote for my tv so when it arrives ill be able to fix teh overscan in the tv.
Pages: << < (3/3)
Go to full version
