Author Topic: Sanwa Joystick Lube - Dow Molycoat 44 Medium Grease or ________________?  (Read 4167 times)
Turambar
  • And I don't watch Fox news or use Happ joysticks.
  • Last login:October 03, 2021, 11:10:13 pm
  • Owner of Wayback's Arcade
    • Wayback's Arcade
So I took apart my joysticks to make jigs, and I want to re-lube them before I get to using them a lot.  Lizard lick sells Dow Molycoat 44 Joystick Grease, but a tube of it is 1)not cheap and 2)way more than I need.
Is there a more readily available alternative that can be found at Lowe's or Home Depot?
RandyT
  • Last login:Yesterday at 12:12:44 pm
    • GroovyGameGear.com
Check out some stuff called "Super Lube".  It's a thick silicone lube, so it stays put.  Just a thin coat will do the trick.
Not sure if they have it at Lowes or HD, but if you have a Harbor Freight nearby, they should carry it.
Turambar
    • Wayback's Arcade
Thanks, Randy!  I will give that a try.  I am also excited because I am about to wire up the trackball I purchased from you a few months ago!
EvilGreenDevil
  • Last login:June 10, 2016, 01:50:45 pm
    • press start to continue
Is this really that necessary if you are just opening it to trace for a jig?  Especially if the joystick is new.
I am here: http://tapatalk.com/map.php?kvdd2f
Xbox360 GT - EvilGreenDevil | twitter - dcmyers
My First Bartop Build
RandyT
Can't hurt, so long as you don't overdo it.  A little preventative maintenance is a good thing, especially if you expect them to see heavy use.  I use the SuperLube on OMNI2's when I build them, and they move really nicely afterward.  I expect that it will significantly reduce wear in the otherwise dry socket.  Joysticks of similar design should also benefit from doing this.
Turambar
    • Wayback's Arcade
It is if you get mdf dust in everything  :banghead:
RandyT
Definitely make sure you get all of that out before applying any kind of heavy lube.  Otherwise, it will mix in and end up being some nasty gunk that will eventually cause you problems.
Turambar
    • Wayback's Arcade
As a guy who has never been accused of being AR in his life, I have been ridiculous about making sure the sticks were completely clean.  That is why I am having to purchase the lube.  I did find a place on ebay to purchase a smaller amount of the Dow lube, but I will definitely be going to check out that super lube that you mentioned.
Turambar
    • Wayback's Arcade
RandyT
Randy, is this the super lube that you use?:
http://www.amazon.com/Synthetic-Grease-Syncolon-Purpose-Lubricant/dp/B000XBH9HI/ref=sr_1_1?ie=UTF8&qid=1332346471&sr=8-1
That would be the stuff!  The rave reviews are spot on.  I use it for just about everything as well.
EvilGreenDevil
Alright, I'm convinced. Maybe I'll pick up a tube for when I mount my CP
