March 17, 2026, 03:55:18 am
Where do you plan on putting the seams in the t-mold (where both ends meet)? Under the glass right by the controls?
What about trying to solder the edges of the trim together.
Why don't you tarp and tape the complete project around the t-molding seam then bondo, sand, and paint?
QuoteWhy don't you tarp and tape the complete project around the t-molding seam then bondo, sand, and paint?I'm not sure what you mean exactly... and it sounds like a ton of work
The seam that you tried to blowtorch, just cover it with bondo and sand smooth. Without dry time maybe 20 minutes of work. You'll want to use a bit of painters tape and/or some plastic to protect the areas around the seam.
I see a wild Nissan 350Z in the background.
How about painting the seam of the T-mold with white or clear paint to keep it from becoming a possible dust trap?
QuoteWhat about trying to solder the edges of the trim together.I didn't take any pictures of me sanding it because that part sucked and I don't want to remember doing it.
Can't wait to see it fully assembled.
Wow! Thanks for all of the awesome comments!!! It is so cool to know people like something that I spent a lot of time working on. I am still actually working on the cab. I am waiting for a LED harness to come in from ultimarc so I can shed some light on the side buttons. I am also working on putting some ground lights under the cab as well.I have hit a small problem however. I want to make an on off switch that works for the computer and the tv but I really have no idea how to do that. I assume I can take my tv apart a bit and add some wires leading back to an external switch but I would really like to see someone who has done this already so I don't make a mess of it. If anyone can help that would be awesome.Here are a few more pics of the machine up and running. I opened the windows to get some nice glass reflection. I also spent all weekend getting hyperpin installed and visual pinball running. (not as easy as I had hoped )Playing pinball on the cab is a ton of fun!Thanks again for the comments. I'll post more pictures when the LEDs are all in place.Again if anyone has a solution to installing a master power switch let me know.
Does Hyperspin handle vertical layouts now, or do you just have it horizontal?
Get a DPDT (or SPDT) momentary switch. Wire one side for your computer's power, and the other side for your TV's power.
QuoteGet a DPDT (or SPDT) momentary switch. Wire one side for your computer's power, and the other side for your TV's power.This is looking like a good idea. Thanks. I am assuming most momentary switches on tvs and computers use ground to activate so attaching them to the same switch would be fine. I guess I'll find out either way.
Ok. So for start up I would just toggle back and forth and both would turn on. That makes sense. Thanks.
Love this build! Would you be willing to share the measurements so I could build one like it?
