Main > Main Forum
Crimp connections keep coming loose from buttons
Pages: << < (2/2)
gurnie:
If this makes any sense the female crimp part of the wire that goes over the male button switch is slipping off he male. If I can just go in and just use pliers and tighten the female over the male then that's easy. I didn't know if doing that would screw with the wiring.
Thank you for taking he time to help!
Jack Burton:
It wouldn't screw with anything.  Go ahead and squeeze it a little with some pliers.
gurnie:
well it all worked wonderfully and the arcade is back in business.  I was happy to play mario brother last night  ;D  Thanks for your help
yaksplat:
This is the only thing that i use.
The right tool for the job works perfectly every time.
BobA:
Have one of those too, but not everyone can afford one for a single cab.   The old crimpers work ok if you are careful.
Pages: << < (2/2)
Go to full version
