Main > Main Forum
Build an OND designed cab 'Metropolis'
ZTylerDurden717:
--- Quote from: Gilrock on February 20, 2019, 04:33:50 pm ---Yeah for my last control panel I cheated. I tried to cut all the angles I needed at first but I had a house shaped box so the angle pieces up front needed a compound angle cut. So I got the bright idea to position my control panel base on my CNC at the angle I needed to make the surface I wanted to be flat parallel with the CNC table. Then I started up the router and used manual jogging to shave off a few mm of wood to make a nice flat plane that would be at the correct angle.
Wow, impressive. At least I'm not using a chisel. ;D
Gilrock:
Nothing wrong with a chisel. I had one in my hand yesterday...lol.
fastbeagle:
What I like about this build is that it has a rectangle control panel, that looks like it could double as a pinsim controller that could play VR pinball( https://www.tested.com/tech/gaming/569647-how-build-pinsim-virtual-reality-pinball-machine/). Has anyone made one of these OND cabinets ,with solenoids and plunger for VR pinball?
ZTylerDurden717:
--- Quote from: fastbeagle on February 23, 2019, 01:56:08 am ---What I like about this build is that it has a rectangle control panel, that looks like it could double as a pinsim controller that could play VR pinball( https://www.tested.com/tech/gaming/569647-how-build-pinsim-virtual-reality-pinball-machine/). Has anyone made one of these OND cabinets ,with solenoids and plunger for VR pinball?
What an awesome concept.
fastbeagle:
I think the illusion looks pretty good. i haven't seen any builds combining VR pinball with an arcade cabinet though.....maybe because a computer that can handle VR is probably going to be your main personal computer :). I can only imagine what will be available within 10 years. Maybe a raspberry pi that can handle 4k VR pinball? LOL
