Main > Main Forum
Build an OND designed cab 'Metropolis'
Pages: << < (118/143) > >>
vaderag:
Super Bubble Fighter II Turbo guys... ;)
Sent from my Mi A1 using Tapatalk
ZTylerDurden717:
Hi all,
I'm looking at the attached cutting plans from post #61 to begin.  Is there a larger graphic somewhere else?  It's a bit hard to read the measurement numbers.  Thank you!
edit: found it!
Ond:
Those plans have an error in the measurements somewhere (I forget where) so you''ll need to make some small adjustment.  It's no big deal though.
ZTylerDurden717:
OND,
Thanks for confirming!  So you know I've been hauling wood to my garage to get going on this project.  I'm not gonna lie it was pretty intimidating transporting 96lbs of MDF  :dizzy:
All,
Does OND's schematics allow for LCD sizes larger than 23-24 inches without fundamentally altering the width structure of the cab?  I guess what I'm asking is, if I were to follow the step by step instructions of the schematics, is there overhead to fit a 32" 16:9 LCD with relatively slight adjustments?  I ask because I would consider covering the letterboxing if it meant gaining about 6" in proportional size relative to a 20.1" LCD. I also ask because since I'm new to this I don't know where I would make adjustments and if it's even worth it from a retro design perspective.
The Sega Astro City cabs used CRT's that were around 27", hence my target size.
vaderag:
No chance.
I have 28" monitor and had to increase width in the designs
Go to full version
