Main > Main Forum
Build an OND designed cab 'Metropolis'
vaderag:
--- Quote from: stigzler on September 22, 2016, 04:01:56 pm ---Well, tbh, I haven't put it on yet. However, I got two other samples either side (commonly in the uk they're "light tint" and "dark tint"). I can't remember the light indexes on these, but dark lets less light through than the 36% and was TOO dark. The light was too light (and let more light through than the 36%). So I'm pretty confident the 36% will be fine.
I think I just made that WAAY more complicated than it needed to be.
Greta value too - came well packaged + plexi in good nick. Can't remember how much the bezel plexi was, but wasn't much. Maybe ask them for samples?
Also - don't forget to get your marquee plexi whilst you're at it.
I went for 5mm on my bezel plexi. Also get some Vuplex and a good microfibre - polishes the plexi quick and effectively.
Great to have another Uk builder! :)
Thanks - was this the one you went for?
https://plasticonline.co.uk/acrylic-sheet/acrylic-sheets/colour-gloss-surface-finish/transparent-tint-gloss/mid-grey-tint-cast-acrylic-sheet.html
Good shout on the marquee - did you go same thickness there too? 2 pieces?
stigzler:
Thimk so but do check with them. My mayquee is slightly different in that I have a dynamic display, bur I went for the 3mm to protect the screen. Youd be best with two sheets of 3mm id suggest.
vaderag:
What's the general consensus on how to hold the marquee and plexi in place at the top? Just wondering if this might affect how i re-do my marquee piece...
GoYouSalukis:
Hello,
Can anyone point me to where a hi-res version of the plan is? All I can find is the image in Reply #61. It has the dimensions, but the image is blurry. I see a reference to a PDF, but haven't found that either.
Justin
vaderag:
--- Quote from: GoYouSalukis on October 05, 2016, 09:04:34 pm ---Hello,
Justin
Here's a folder of what i collected. Anything in cm is not an original plan but my update based upon it. Use with a pinch of salt as something went wrong in my using them resulting in a little less space than others seem to have. Nothing that can't be compensated for with a little more wood (and time) however!
https://1drv.ms/f/s!AoSIS8JMp7e7pdNjAnZ1CZpIdJse5A
