Main > Main Forum
Build an OND designed cab 'Metropolis'
kmccb23:
Has anyone compiled a parts list for this build?
I want to get all the lumber that is needed in one stop.. I see 1/2" MDF 4x4 and then two sheets of 3/4" 4x8 in the design.. But then later in the PDF it shows a 1/2" base that wasn't included in the first drawings..
vaderag:
3 4x8 in the relevant sizes is enough for everything except the back opening panel (tho if you cut it right you might be okay)
kmccb23:
I got the wood and started drawing my measurements on the board.. I'm stumped on how to do the degree/angle measurements.. If there were more measurements given where the angles are, I can simple draw a line to meet two points.. But the PDF I have does not have them..
I've attached an example.. The 15*.. I know the angle starts at 38 3/8" high (shown by red line in attachment).. If I knew the measurement of the other line shown I could simple connect the two points.. So I'm stuck..
How do I figure out these since there are no measurements to connect the points? There are numerous angle cuts that I need to draw but can't..
stigzler:
Similar issue to this guy's post a few posts above?
http://forum.arcadecontrols.com/index.php/topic,118612.msg1572881.html#msg1572881
He seemed to get it solved.
kmccb23:
--- Quote from: stigzler on July 03, 2016, 04:51:59 am ---Similar issue to this guy's post a few posts above?
Thanks for the reply.. I did see that after I posted, however, the drawing you posted that helped him out seems to be a modified plan of what the OP originally posted..
Was hoping to use the OPs plans..
