Main > Main Forum
Build an OND designed cab 'Metropolis'
stigzler:
Ah! Yeah - I've used that - absolutely brilliant results. As per here:
https://sites.google.com/site/alienarcade74/sub-projects/conrtol-panel#TOC-Mini-Trackball-Module
You should have no dramas. Build thread?
vaderag:
--- Quote from: stigzler on January 07, 2016, 01:36:43 pm ---Ah! Yeah - I've used that - absolutely brilliant results. As per here:
I have a thread set up ready to be my build thread. I still don't have the wood yet tho!!
Need a dry day so I can have it delivered without it soaking through since water + mdf = doom!!
LiquidFlame:
I just got done reading this entire thread, and I'm so glad I found it. Thank you so much to everyone that has put all this time and effort into this. I can't wait to get started, but I'm really debating on cutting everything myself or sending the CNC files to my local machine shop that I've worked with before. It's winter here now, so I can't work in the garage cause it's to cold. I really like building things with my hands, but the urge to start this now is pretty overwhelming, I'll have to see how much they charge.
I have a bunch of questions swimming around in my head, but I'll just start of with these few.
* Going of of the PDF plans it looks like the measurements of this cab are the following: H: 75.25" W: 25.5" D: 23.25" Am I correct?
* What is the difference between the METROPOLIS_ARCADE_CAB-ACAD2000 and METROPOLIS_ARCADE_CAB-ACAD2004 files
* If I read everything right the monitor that was planed for this is a 23" Widescreen, so 1920x1080 correct?
stigzler:
There are CNC files?
LiquidFlame:
--- Quote from: stigzler on January 12, 2016, 12:26:31 pm ---There are CNC files?
As far as I know .dwg & .dxf files can be used/easily converted for use for CNC machines. I could be wrong though.
