Main > Main Forum
Build an OND designed cab 'Metropolis'
Pages: << < (82/143) > >>
vaderag:
--- Quote from: stigzler on November 28, 2015, 06:36:46 am ---If you can, I'd definitely try and get hold of a 16:10. Took w while here in the UK, but the extra height worth it imho.
Where in the UK did you find one? Looks like a £200+ premium for one at which point may as well get the next size in 16:9, no?
stigzler:
I picked one up 2nd hand off ebay fro under £50. Can't remember size - maybe 24" - filled bezel space, anyway:
vaderag:
This may be a dumb question, but do you remember what you search for? I've tried 16:10 but it doesn't handle the search term well... :(
JudgeRob:
If I were you, I would just increase the width of the boards from 24" to 26" and go with the 28" TV.  I would probably consider that now, if I didn't already make all the cuts.
vaderag:
Just ordered a 24" 16:10 monitor :)
One thing that I didn't spot in OND's instructions is how the monitor is fixed?
I've seen people screw into the VESA points and saw that he routed out the bezel area for the monitor to slot into, but where did the piece that has the monitor screwed into affix to?
Go to full version
