Main > Main Forum
Build an OND designed cab 'Metropolis'
rvs0002:
I think I ordered 30 feet and had about 5 feet left over.
edge929:
For my SF build, I ordered 40 feet, made one mistake around the CP and had just enough left to go around it again.
DzMiniz:
--- Quote from: Ond on May 03, 2015, 07:58:29 pm ---Just a quick note, I have (temporarily) removed the PDF plans for this design while I update with new build plans for both Metric & Imperial versions with some corrections and clarifications which have no doubt annoyed some in the past. New version will also include some CP variations based on the good work done by other members here. :cheers:
I was wondering where they were at. Kept seeing all the references to downloading the plans.
Hope ya get em fixed/posted up soon. Plan on starting a build (finally).
brihyn:
OND-
Not sure how far along you are on updating the plans, but if you need a tester, I'm a few weeks away from cranking up the "Metropolis factory" and would be happy to compare the plans as I build with the previous plans (Have them printed out with a bunch of scratch notes from the last 2 cabs).
Lemme know.
-Brian
stigzler:
Dunno if this is helpful, but due to the errors in the original plans, drew up my own metric ones at the bottom of the page, here:
https://sites.google.com/site/alienarcade74/sub-projects/cabinet-design
Alterations mainly around the Marquee and obviously the CP area, but should be amendable.
