Main > Main Forum
Build an OND designed cab 'Metropolis'
Toasta:
I was wondering if anyone knew the angle of the marquee. I've looked through the drawings and I can't make it out.
And thank you for posting Metric diagrams.
eds1275:
I was looking at this design, and I think that if you were going to incorporate guns into it, you could push the lower front in a few inches and have the part that juts out with the coin door stay near the front. Then you could hide holsters on the inside, if that makes sense... here's a photo to illustrate.
stigzler:
Just a quick update on my modular variation of this design. Some update pics:
Racing against the winter now! No garage or workshop, so gotta try and fit in CP Panel Routing, sanding and spray painting before the weather cometh!
This project really needs to end!
stigzler:
--- Quote from: Toasta on September 27, 2013, 07:28:50 am ---I was wondering if anyone knew the angle of the marquee. I've looked through the drawings and I can't make it out.
Toasta - dunno if this may be of help: https://c1a1c6d4-a-62cb3a1a-s-sites.googlegroups.com/site/alienarcade74/sub-projects/cabinet-design/cutting%20plan%20overview.png?attachauth=ANoY7cqq5Fq6dn4dU3wzBHO0pvi1cLAzHj6fCl7yw3Ri_SgaVC51o1vuUMkztO26uZn6Fpn97So79ecG-uu1mH9_-Ju3Ft_2ErMDUbbKo6dBH2c0ZFpadY63WBc9eZ3upnHHUApNludsTQD5JY-F1j5BQgt-eGKRFiy51hPzPQOOwjAuMbT--cz9b8JCuLeR5BAqOcTRuFXkNb5vRH7zsRrvcOMsKMy8K7pNfHW-40Qfh8uqJh_rV3ujzv23JQxwt7nTRWjlEtpAsITEI0cFQbvdP0-y1bE0hA%3D%3D&attredirects=0
I did redesign a bit of the marquee, but can't recall how - thank I added two horizontals to 'face off' the angled marquee or something - anywhos, you can check/compare/investigate this here:
https://sites.google.com/site/alienarcade74/sub-projects/cabinet-design
Hope this helps
Batapotamus:
Hi... Just a heads up that I am attempting to build this cabinet also. A very big thanks to Ond for going out of his way for providing this extremely useful information as I have never attempted anything like this before.
So far I have the sides and base done. I will post pictures when I get the chance too however I have been totally enjoying the experience so far. ;D
