Main > Main Forum
Is Tron 4 or 8 way?
Pages: << < (3/6) > >>
trekking95:
EDIT:
What about this, guys? I could always try adding the Tron handle and restrictor to it!
And its cheaper than the crane stick!!!!  :applaud:  :cheers:
;D THEN TRON COULD BE PLAYED THE RIGHT WAY!!!!  ;D
This is it!!!!
Its called the MiniGrip Stick and is about half way down the page.
trekking95:
--- Quote from: mytymaus007 on February 23, 2012, 11:12:44 pm ---Does anyone know if the restrictor plate is also used for DOT i would like to make a control panel dedicated to tron games but if DOT doesnt have restrictor plate then its not worth the effort. Im using a 4 way plus flight stick to plat both Tron and DOT but for a dedicated control panel it will look sloppy!!!
I thought DOT had a button on the back of the joystick. But since I have only seen a few pictures I cant be sure!
EDIT:
Yes they do. There is a thumb button on the back for deflecting.
The picture is part way down this page, its by the member rdagger.
http://forum.arcadecontrols.com/index.php?topic=53406.0
trekking95:
Really guys, I need to know what you think of the MiniGrip Stick!  :)
Le Chuck:
I haven't seen it on a lot of CPs yet.  I made a wireless trigger stick that you can hot swap on and off your panel from a ball top.  Takes about 5 or 6 hours to do some start to finish.  Fun little project.  Put it on an auto 4way to 8way stick that automatically switches to 4way when light bikes comes on.  (that project takes a bit longer).  If you don't mind having the stick there all the time I'm sure Andy's stick would be fine, and you can very likely mod it to a tron handle with a bit of doin'.
darthpaul:
Been waiting for your input on this Le Chuck, I'm considering attempting your Tron solution.
Go to full version
