Main > Everything Else
High Power USB at every wall socket.
lilshawn:
--- Quote --- Imagine if you could carry around a single cable and plug in any device to the wall, in any country.
does this guy not know that the chargers supplied with your gadgets use a SMPS power supply that can take voltages from anywhere you might plug it in. 90-260 volts? unless you need to plug into some 400v feeder line, I don't see an issue.
--- Quote --- Gone are the wobbly, prone-to-falling-out, who-needs-an-earth?! US plugs
huh??
the only time i've seen a wobbly plug is cause of a broken socket. :angry:
--- Quote ---A dreamy smile spreads across my face as I imagine life with universal power sockets and cables.
uhm. kay. last i heard power plugs where all the same. (at least by region)... last I heard USB sockets where all the same. Last I heard as of 2010 all new cellphones where coming with microUSB.
sounds pretty standard to me.
--- Quote ---You could have wall sockets with built-in power cables. Imagine: A wall socket with a retractable Micro-USB connector sticking out of it. Just pull it out, stick it into your laptop/smartphone/tablet, and off you go. Salivating yet? I am.
guess this guy never thought this through...I'm not even going to bother with how stupid THAT particular statement is.
EDITED TO ADD:
i'd be happy with maybe a 5 amp power supply with a cord that comes up on my desk or table or whatever and has a terminal of say, 15 USB sockets. that way i can just plug in whatever and charge.
Navigation
[0] Message Index
[*] Previous page
Go to full version
