Author Topic: What am I doing wrong? I can not get these templates to print to size???  (Read 2194 times)
pharoah007
  • Last login:June 29, 2017, 07:27:26 pm
  • Why buy it when you can BUILD it!
I am trying to print out one of these templates in actual size so I can move it around on my CP and finalize the hole locations.
http://www.slagcoin.com/joystick/layout.html
I can not seem to get the one I like to print to exact size?  I need all the holes to be 1 1/8th at the very least so I can plan my layout.
any help would be awesome.
Thanks all.
Re: What am I doing wrong? I can not get these templates to print to size???
« Reply #1 on: February 07, 2012, 08:17:21 pm »
Quote from: slagcoin
These images are produced to scale. If you want to print them, note the PPI. For example, the first linked 300 PPI image is 2808 pixels wide. So to make a scale print, make sure the printer prints it 2808 / 300 = 9.36 inches wide. And if you want to change the spacing in the images by a certain scale, multiply this number by an appropriate percent. So for small buttons, 30mm spacing is an appropriate spacing; 30mm / 36.5mm = 82.2%; .822 * 9.36 = 7.69 inches wide. You need to figure how to place the joystick separately if you do this.
If you still can't get it to work, there's always the measurements from the layouts you can use to duplicate them.
  • Last login:May 05, 2024, 08:59:50 am
« Reply #2 on: February 07, 2012, 08:31:31 pm »
Try printing it from a different program.  That friggin windows photo printer helper thing ruins everything  :angry:
In vista, I used Paint to print out things that I needed actual size.
Since they've updated paint for Win7, that might be ruined now too.
pharoah007
« Reply #3 on: February 07, 2012, 08:41:41 pm »
I have a comp with 7 and a comp with XP.  I will try printing from them.
Thanks guys,  I will post my results.
abispac
  • Last login:Today at 08:02:50 pm
« Reply #4 on: February 07, 2012, 10:19:24 pm »
when printing in real size, always use paint on any xp,vista o 7 computer, it works all the time, ...
pharoah007
« Reply #5 on: February 08, 2012, 04:16:44 pm »
Thanks everyone.
I printed the layout in XP via Paint today and it worked perfect.
Thanks again.
