Author Topic: Computer built, emulators running - now I discover a problem  (Read 1875 times)
Jasonlyvers
  • Last login:July 11, 2012, 07:43:16 pm
« on: February 07, 2012, 07:06:44 am »
I have everything built and running with my frontend (HS).  My problem: I'm using Win 7 64 bit, and soft 15 appears to not work on Win 7.  I'm using integrated graphics (which works fine).  Here are my options:
  • Switch to XP 64 bit, install soft 15 (can I still run with integrated graphics, or do I need a GPU?)
  •     This would require a JPAC
  • Sell my arcade monitor, drop in a 27" TV and use an HDMI to Composite converter
  •     I think the JPAC is out since there is no arcade monitor, would need to switch to an IPAC?
Any other ways to fix this issue?  What would YOU do?
« Last Edit: February 07, 2012, 07:10:38 am by Jasonlyvers »
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:Yesterday at 09:33:37 pm
  • Worthless button pusher!
Re: Computer built, emulators running - now I discover a problem
« Reply #1 on: February 07, 2012, 07:54:20 am »
Why would switching OS require you to get a JPac ?
Working: Not Enough
Projects: Too Many
Progress: None
Ansa89
  • Last login:December 09, 2016, 10:40:11 am
« Reply #2 on: February 07, 2012, 08:04:33 am »
I think he build/configured a pc using a normal 31KHz screen.
Now he wants to put that pc into a cabinet and (obviously) he needs a pc_to_jamma connector.
IMHO the best choice is to buy a jpac/jammasd and eventually a graphic card and use soft15khz.
If you wanna use a normal tv, then I suggest to build a vga_to_scart cable for better video result.
Earth could be the hell of another world
Jasonlyvers
« Reply #3 on: February 07, 2012, 08:34:05 am »
I appreciate the quick responses.
Sorry, wasn't clear.  Switching doesn't require it - I have to buy it if use an arcade monitor.  If I don't, I can skip it and use an iPac to hook up my controls and send the signal to the TV directly.
Any recommendations on a card that is VERY compatible/stable?  I'm a little tired of building and tweaking. I'm way over budget already - I can run everything I play on integrated graphics, so the card is only required to support Soft 15 - price is a definite concern at this point.
Ansa89
« Reply #4 on: February 07, 2012, 08:46:38 am »
ATI radeon HD4850 or ATI radeon HD5450 or ATI radeon 9200.
I know these cards to work well with linux, so I think they are good also for soft15khz.
isucamper
    • my project arcade blog
« Reply #5 on: February 07, 2012, 08:49:35 am »
For what it's worth i run soft15k on my integrated graphics card.  Can't remember the PC model at the moment but its a Dell and the graphics chipset is nvidia.  It's quite and cool.  If you can get away with this, I highly recommend it.
THE SYSTEM          Popeye
Green Giant
« Reply #6 on: February 07, 2012, 10:32:31 am »
Personally I would sell the arcade monitor, get a 27" TV with component (assuming you are in the US), get an hdmi/dvi to component connection.
You walk away with a profit, and there are probably only 10 people alive, who are only on these forums, would be able to notice something strange about your monitor.
A composite TV is not enough.  If you can snag some sort of component type input you are good.
Toxic Arcade, my first build
wizkid32
  • Last login:August 30, 2013, 07:27:03 pm
  • Portland Trailblazers, FTW!
« Reply #7 on: February 07, 2012, 11:14:40 pm »
I'd go with the IPac and T.V., unless you have a compelling reason to do otherwise.
(\__/)
(='.'=) This is Bunny. Copy and paste him into your
(")_(") signature and help him on his quest for world domination.
Best,
Wizkid32
