Main > Everything Else
Danish Pastry guinea pigs needed
<< < (46/54) > >>
Dervacumen:
--- Quote from: Hoopz on April 13, 2012, 09:43:29 am ---
--- Quote from: Dervacumen on April 12, 2012, 08:01:58 am ---Cinnamon.  Would you still want almond paste, or just a cinnamon and sugar filling?  The production process for these always results in shreads and pieces of left over dough.  Ususally when I'm done for the day I take all of these shreads which contain bits and pieces and globs of various fillings from the day and mix them with sugar and cinnamon, cut them in to bite sized pieces, and bake them in a loaf, like pull apart sticky buns.  They are some of the best things I make, really.  They're full of chewy carmelized goodness with little surprises of fruit every few bites.  I'll sell this by weight.
I didn't have almond paste (cherry filling instead) but I would want just cinnamon and sugar without any other filling.  caramelized cinnamon is more than enough by itself.
My mom makes a dish called a plucket that sounds a lot like what you do with your leftovers.  Delicious.
Yours had almond paste as a base with cherry as an addition.  Everything I've sent has had almond base as  base.  I guess I can make something with no almond paste.  I'll do that and see how it works out.  I'm sure it will taste good, just have to play with the filling a bit to get the right consistency.
Hoopz:
I didn't realize that.  Regardless, it was great.
lanman31337:
Some shippers are using thin brown paper instead of packing peanuts.  it's inexpensive and not as messy as the packing peanuts.
Dervacumen:
--- Quote from: Vigo on April 05, 2012, 06:35:52 pm ---Just looking at the pictures, I think you should change the font you use to state the flavor on the packaging. Comic Sans does not mix with elegant pastry in my mind.
I'll change the font anyway, but turns out I used Tekton Pro, not Comic Sans.  FWIW.  There doesn't seem to be the same backlash against this font.
shmokes:
I think probably not worth too much. I can't think of a situation where using a font that appears to be Comic Sans would be any more appropriate than using Comic Sans.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
