Main > Main Forum
Lighting Paradise Arcade 5v LED Lighted Arcade Pushbuttons
Pages: << < (3/3)
gatordad:
If i'm not mistaken I believe that you can tap 5v from the ipac if thats what your using as an encoder.
gatordad:
Found it here
http://www.ultimarc.com/jpac2.html
Scroll down to header plug diagram
I lit my leds on my trackball this way
daillest319:
gatordad,
               that would be perfect. I had question would led wiz be able to light my buttons?
I have an led wiz this one excact
http://groovygamegear.com/webstore/index.php?main_page=product_info&cPath=82&products_id=239
if it can't light my buttons ill purchase the ipac then.
gatordad:
The Led Wiz gives so much flexibility for lighting buttons
It's programmable!
I was just pointing out an option for grabbing 5volts off of the button and control encoder (ipac)
Both Vendors are great
Groovy Game Gear and Ultimarc
BobA:
The LED wiz will power the 16 single color buttons you have but you will have to supply it with a USB connection. I do not know how you will program the LED wiz and get it to operate without a computer.  You can just use a direct connection to your arcade power supply 5V and ground to run your LED buttons.  In that case you do not need and LED wiz.
Pages: << < (3/3)
Go to full version
