Main > Main Forum
Ledblinky Mame missing something
Pages: << < (3/3)
spkywlnt73:
--- Quote from: Nephasth on January 31, 2012, 08:40:09 pm ---Beats me then. :dunno
Well, if I figure it out, I'll let you know. Thanks anyway!
DaveMMR:
I don't have LEDBlinky in front of me (full disclosure - don't feel like booting up the cab to access it right now) but I know there should be a program where you can light up each individual light to test them or set up animations.  If it passes that test, it's gotta be something with the configuration.  If that's the case, delete the settings and try remapping the LEDs.
How many LEDWizes are you using by the way?  If you're using more than one, they have different ID's, correct?
spkywlnt73:
--- Quote from: DaveMMR on January 31, 2012, 09:50:50 pm ---I don't have LEDBlinky in front of me (full disclosure - don't feel like booting up the cab to access it right now) but I know there should be a program where you can light up each individual light to test them or set up animations.  If it passes that test, it's gotta be something with the configuration.  If that's the case, delete the settings and try remapping the LEDs.
I'm using three LEDWIZs. I've reset the LEDs twice,and even went as far as deleting the program and reinstalling it! Still nothing! I think it has somthing to do with the controls "ini", but I'm not sure how to add the button configuration to it. I believe that even if you hit TAB and go into Mame that way and change something, it doesn't show up in the controls "ini". I think the problem I'm having is that I have 8 buttons per player, by default I think Mame only see's 6 per player. Thats why the other 4 buttons are not lighting up during game play. Whats wierd, is that I can go into LEDBLINKY and setup/assign the LEDs just fine in the program, hit save, reboot, launch into Mame and it moves the lights on player 2 the default settings!? There has to be someone out there that has a similar setup?
arzoo:
My guess is your LEDBlinky config setting for the path to the mame cfg folder is not correct. The path should end with \cfg
Check these support links on the LEDBlinky site;
http://www.dndw.com/ledblinky/Support.htm#MAMEP2B56Problem
http://www.dndw.com/ledblinky/Support.htm#MAMELEDProblem
If that doesn't help, turn on the debug.log and verbose options (on the Misc Options tab), run some games that use the problem buttons, then email me the debug.zip file and I'll take a look.
spkywlnt73:
--- Quote from: arzoo on February 01, 2012, 08:53:37 am ---My guess is your LEDBlinky config setting for the path to the mame cfg folder is not correct. The path should end with \cfg
That was it! I had the path set up, but it stoped a Mame! I just had to add the /cfg, and it fixed it. Thank you so much!  :notworthy: Now, if I could only get all my emulators setup right, I'll be able to play around some more with this awesome program! Thanks again! :cheers:
Pages: << < (3/3)
Go to full version
