Main > Everything Else
Possible to connect this SSD to a SATA connector?
<< < (3/3)
lilshawn:
--- Quote ---What you have there is very likely what is being called "mSATA".  Basically, it's SATA on a mini-PCIe slot.  I very much dislike this because they're not really compatible in any way whatsoever.  They just re-used the connector because it was convenient.  It would be like putting Ethernet on a USB connector "because we had a lot of them laying around" (hey, kinda like the JVS IO "standard").
and then companies start wondering why the get damaged product back cause users plugged ---steaming pile of meadow muffin--- into the wrong connector. THERE IS A REASON STUFF HAS DIFFERENT CONNECTORS ON THEM!!!
jimmy2x2x:
Thanks for all the (various) information, I think I will leave it where it is ;)
lilshawn:
/btw they do have a mini sata to standard sata adapters available.
rockyrocket:
So I just tried the same thing with the exact same drive, bought one of these adaptors..
http://www.amazon.co.uk/RunCore-70mm-50mm-Converter-Adapter/dp/B003BK4OZ8
And everything fits fine but it turns out the drive uses pata (it is infact described as a pata ssd) so no it did not work.
Shame as I had plans for it!.
Navigation
[0] Message Index
[*] Previous page
Go to full version
