Author Topic: Standard cocktail control panel widths  (Read 1672 times)
Mental
  • Last login:May 18, 2013, 09:46:08 am
    • Complete cocktail arcade system
« on: January 31, 2012, 01:18:46 pm »
I am in the process of designing a cocktail cab and am wondering what the standard CP widths are. I've seen both 9" and 11'' mentioned, but is this an exact measurement? I see Arcade Depot sells these two sizes as well, but are they also exactly 9" and 11"? or are they 11.25" or something?
Ideally, I'd like to replicate an early 80's Midway cab.
Complete cocktail arcade system: arcadecabinets.ca
Gaaargh
  • Last login:April 20, 2023, 02:27:52 pm
Re: Standard cocktail control panel widths
« Reply #1 on: January 31, 2012, 05:42:39 pm »
I have an arcade depot cocktail kit, with 9" control panels. The actual space between the sides is about 9 1/4".
The 9" control panel set sold by Mike's Arcade Link is supposed to be a replacement for Ms. Pac-Man or Galaga, and fits the arcade depot kit perfectly.
« Last Edit: January 31, 2012, 05:50:12 pm by Gaaargh »
Kludged together a MAME cab 10 years ago, it got a makeover January 2012
2012 - built a cocktail Pacman near-repro running 60-odd vertical games Link
Mental
« Reply #2 on: February 01, 2012, 09:11:13 am »
Thanks for the reply Gaaargh. I see on the Kyle Lindstrom plans, he specifies 9 and 3/16" so sounds about right for what you have as well.
Still not sure about the 11" panels. I've read that PacMan used 11" and Galaxian used 11.25".
dextercf
  • Last login:December 10, 2022, 05:26:18 pm
  • [thisispersonal]
« Reply #3 on: February 01, 2012, 09:51:13 am »
I could measure up this one for you later, if this is relevant?
More pics here, if that is needed...
CWorley
  • Last login:August 09, 2019, 07:44:36 pm
« Reply #4 on: February 01, 2012, 11:24:38 am »
I believe the 11" Pacman control panels are actually 11".  If anything else, they're a hair smaller at 10 15/16".
Mental
« Reply #5 on: February 01, 2012, 11:32:34 am »
That makes sense, don't want too tight a squeeze. So if I build for 11", a standard CP should fit right in.
*Crosses fingers
