Main > Everything Else
Can't burn ISO - okay, this didn't get solved.....
<< < (2/6) > >>
ark_ader:
--- Quote from: Gray_Area on January 25, 2012, 11:39:45 pm ---
--- Quote from: ark_ader on January 25, 2012, 05:40:59 am ---
--- Quote from: Gray_Area on January 24, 2012, 07:39:23 pm ---I'm trying to burn a 3.5gb image to an Imation 4.5gb DVD-RW. It says video and data on it, so I assume it can do both.
I'm using Nero 6. When I start the burn process, the disc ejects, and Nero says there's an error. In part of the log, it says 'illegal disc'.
I don't get it.
You are burning it in the UDF format right?  Gotta watch that 2gb Limit on 9660.
Originally, I selected copy and back-up>burn image to disc, and selected the directory. When that didn't work, I tried 'data>make bootable DVD - which is where it said '2gb limit'.
I have written data of up to 6.5gb on a DVD using nero. Just not with these particular discs (25-pack). Tried another one in the set, same behavior.
I like Verbatim DVD media and anything that has Ritech (Dye).  You can overburn Ritechs and they seems to be more compatible with other readers and burners.  Sony DVD media on the other hand is just rubbish.
But any image over 2gb you need to burn it in the UDF format.
spoot:
--- Quote from: ahofle on January 24, 2012, 09:51:51 pm ---Try ImgBurn: http://www.imgburn.com/
+1 Have had very good luck with it...and price is right.
TopJimmyCooks:
+1 to Ark_ader . . . if you want to eliminate the media as a possible problem, Taiyo Yuden or Verbatim are the best.
SNAAKE:
nero know you are burning illegalz discz :hissy:
Gray_Area:
--- Quote from: SNAAKE on January 28, 2012, 08:18:11 am ---nero know you are burning illegalz discz :hissy:
Hmhmhmh. I wouldn't think so. I've used this same nero to write tinyXP 10 and 11, to
DVD and CD, respectively.
I didn't see any option for 'UDF' in Nero.
I just tried ImgBurn. Errored out, too. I guess the discs can only be written at 1x .......(?????)......so I tried that in Nero, and same problem. These discs are maybe only made for video? They're DVD-RW, and say 4.7gb  2 hours video.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
