Main > Everything Else
Can't burn ISO - okay, this didn't get solved.....
Gray_Area:
--- Quote from: HaRuMaN on March 01, 2012, 02:36:54 pm ---Why are you using RW and not just R? I've had issues in the past with RW discs.
That's why I mentioned they were RW. Could be it. It's definitely not the drive, at least regarding CD media. I just burned XP onto a fifteen-year-old NIC gold archive CD, and using it to install on a machine right now.
And, as said, I've used nero to burn TinyXP 10, which was over a gig. Also did two CD of music of a few gigs each. Used the exact same PC system in all three cases.
I just tried to put a smaller image on it and nero said it was the wrong media. I'm thinking these are weird discs.
Gray_Area:
I was initially using Nero 6. Using Nero 11, I was able to write a gig+ to these discs. Don't know what's different, but it works.
kahlid74:
--- Quote from: Gray_Area on April 06, 2012, 11:10:15 pm ---I was initially using Nero 6. Using Nero 11, I was able to write a gig+ to these discs. Don't know what's different, but it works.
Well for starters Nero 6 was around about 10 years ago, whereas 11 is built for newer devices. So yeah, gotta use the latest version. Also, just use Imgbun. Can I assume you're using an illegal copy of Nero? The reason I say that is I was in the same boat as you. I used illegal 6 for so long and then it started acting up. Then used illegal 11 and then just went to Imgburn. So much simpler and it's free.
Gray_Area:
--- Quote from: kahlid74 on April 09, 2012, 08:17:57 am ---
Above, I mentioned I had the same issue with IMGburn. I don't recall where I got Nero from.
Oh, and I didn't have to select no 'UDF' nothin.
Gray_Area:
Well, I thought this was solved. However, the Nero 10 disc I created wouldn't boot. So I tried the latest IMGBurn: the disc wrote, but failed the verify. I found similar reports, but no solutions.
Note that this last effort was on both my old system and a completely different system (hardware and OS installation). So I think I can safely say these discs are bad. Too bad they're a few years old. But cheap enough.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
