Main > Everything Else
Can't burn ISO - okay, this didn't get solved.....
<< < (4/6) > >>
lilshawn:
windows 7:
right click .iso file -> click burn disk image.
TA-DA!
Gray_Area:
--- Quote from: lilshawn on February 27, 2012, 08:04:35 pm ---windows 7:
TA-DA!
Hmm. I'm going to be switching to a duo core for my general purpose rig (finally making my old main rig arcade-dedicated), so I probly should move up to that. Hadn't though of it, though, so thanks.
Dervacumen:
I'm no expert, but it seems to be an incompatibility with your drive and the media.  Try updating your firmware for the drive to see if that helps recognize the media.  I suppose the media could be bad, but I've never run across that.
lilshawn:
it's not entirely uncommon for cd drives to just go tits up.
is it reading regular cd's okay? perhaps the blank media is incompatible with the drive.
i had an HP cd burner that would not write to verbatim disks...changed to sony....no probs.
HaRuMaN:
Why are you using RW and not just R?  I've had issues in the past with RW discs.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
