Main > Everything Else
Can't burn ISO - okay, this didn't get solved.....
<< < (3/6) > >>
ark_ader:
--- Quote from: Gray_Area on February 02, 2012, 03:23:05 pm ---
--- Quote from: SNAAKE on January 28, 2012, 08:18:11 am ---nero know you are burning illegalz discz :hissy:
Hmhmhmh. I wouldn't think so. I've used this same nero to write tinyXP 10 and 11, to
DVD and CD, respectively.
I didn't see any option for 'UDF' in Nero.
I just tried ImgBurn. Errored out, too. I guess the discs can only be written at 1x .......(?????)......so I tried that in Nero, and same problem. These discs are maybe only made for video? They're DVD-RW, and say 4.7gb  2 hours video.
You have to use the Main Nero Program and I do believe UDF is under ISO format on one of the options.
Illegalz...and Tiny XP  :P
Richard_Nixon:
Here is a couple things you could try:
-In Nero, try selecting "Determine maximum speed" in the "Burn Compilation" Window
-Upgrade the firmware of your DVD drive. Heres a link, youll have to find the model. http://www.samsungodd.com/eng/firmware/fwdownload/fwdownload.asp
-Clean the laser
-Trade your spindle of disks for a friends spindle. (If they work for him that is)
-Buy/use another DVD drive.
Oh, and there is no such thing as disks made only for video.
Gray_Area:
I don't see any UDF format selection in either of these programs. I'm wondering why it ain't automatic.
Not that I haven't burned a 1+gb image using nero, just by pressing the button. These discs must be bad.
ark_ader:
--- Quote from: Gray_Area on February 27, 2012, 01:07:04 am ---I don't see any UDF format selection in either of these programs. I'm wondering why it ain't automatic.
I probably misunderstood you, but UDF is for 3+gb images.  You should be able to burn 1gb in 9660.
Gray_Area:
Whatever, it ain't workin automatically, so I'm done with that.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
