Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
Pages: << < (18/42) > >>
RetroACTIVE:
Yes they do actually.
Calamity:
... so you need to find the right horizontal porch values for the 15 KHz range (monitor_specs0). At this point you should have learned how to do this ;)
I'll be helping anyway...  ;D
RetroACTIVE:
--- Quote from: Calamity on February 27, 2012, 06:56:12 pm ---... so you need to find the right horizontal porch values for the 15 KHz range (monitor_specs0). At this point you should have learned how to do this ;)
Yeah I think I can do this.
The screen is horizontally perfect.  It's far off the left and right sides.
Thanks again
RetroACTIVE:
Oh it did work before the scramble tweak.
RetroACTIVE:
ok... I went back and retested each of the monitor settings we used and could not get these two games to work with any of them... I must have been smoking something when I tested them before  :dizzy:
So here is the modeline as it is selected by the game:
H-Settings
V-Settings
Here is what I adjusted the V settings to get the image to correctly size:
Here is where it all landed:
Now I tweaked the monitor_specs0 line to the following:
monitor_specs0    15625-15900, 40-80, 3.090, 4.630, 7.720, 0.648, 0.194, 1.297, 0, 0, 248, 448
... and it didn't seem to change a thing... what did I miss?
Go to full version
