Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
Calamity:
--- Quote from: RetroACTIVE on February 24, 2012, 01:24:46 pm ---Both needed to be adjusted.
Please be more precise. Was the vertical part overscanned or just shifted up/down, or both, how much, etc. :)
(I can just use the values you got, don't worry, it's just to be sure).
RetroACTIVE:
--- Quote from: Calamity on February 24, 2012, 01:32:45 pm ---
Ahh ok. Let me re-test.
I want to say the bottom right of the screen was in proper location, the top and left edges were well out of view.
RetroACTIVE:
That did it for qbert! :applaud:
I went back and checked mk and it appears to have gone out with the change made for tapper and phoenix.
Calamity:
This should put mk back into its range:
monitor_specs0 15625-15900, 40-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 248, 448
monitor_specs1 16000-17200, 58-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 256, 448
monitor_specs2 18300-18800, 40-58, 8.300, 2.750, 9.000, 0.190, 0.191, 1.018, 0, 0, 280, 448
monitor_specs3 18800-19000, 40-80, 2.187, 4.688, 6.719, 0.140, 0.191, 0.950, 0, 0, 320, 448
monitor_specs4 24000-29000, 40-80, 2.910, 3.000, 4.440, 0.451, 0.164, 1.048, 0, 0, 384, 576
monitor_specs5 30000-34000, 40-80, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 576, 800
monitor_specs6 34001-38000, 40-80, 1.000, 3.200, 2.200, 0.020, 0.106, 0.607, 0, 0, 600, 800
RetroACTIVE:
same...
