Software Support > GroovyMAME
Trying to create monitor presets for KT-2914 (Betson-Kortek) MultiSync
Pages: << < (7/42) > >>
Calamity:
--- Quote from: RetroACTIVE on January 27, 2012, 06:43:39 pm ---almost... it fits but the screen is bowed like ( ) and it doesn't look like the resolution is right... not pixelated enough (no visible scan lines).
Yeah, the modeline scoring system is moving that video mode to the 31 KHz range instead of the 18-19 KHz that's what I intended. I'll look for a solution.
RetroACTIVE:
--- Quote from: Calamity on January 30, 2012, 07:56:26 am ---
Ok great, thanks again!
Calamity:
Hi RetroACTIVE,
Try mk now:
monitor_specs0    15250-15900, 40-80, 2.187, 4.688, 6.719, 0.190, 0.191, 1.018, 0, 0, 248, 448
monitor_specs1    18001-19000, 40-80, 2.187, 4.688, 6.719, 0.140, 0.191, 0.950, 0, 0, 320, 448
monitor_specs2    20001-29000, 40-80, 2.910, 3.000, 4.440, 0.451, 0.164, 1.048, 0, 0, 384, 576
monitor_specs3    29001-32000, 40-80, 0.636, 3.813, 1.906, 0.318, 0.064, 1.048, 0, 0, 496, 768
monitor_specs4    32001-34000, 40-80, 0.636, 3.813, 1.906, 0.020, 0.106, 0.607, 0, 0, 576, 768
monitor_specs5    34001-38000, 40-80, 1.000, 3.200, 2.200, 0.020, 0.106, 0.607, 0, 0, 600, 768
RetroACTIVE:
Interesting... almost... it still doesn't quite fit... its goes off the screen on bottom and left edges.
Probably irrelevant but...
Now if I try to set the resolution with the -resolution switch it no longer works properly... (scan lines are not there and it doesn't fit right).
If I create a new mame.ini without these montior_specs I can get the -resolution command to work the way it did.
Calamity:
Try now:
monitor_specs1    16700-19000, 40-80, 2.187, 4.688, 6.719, 0.140, 0.191, 0.950, 0, 0, 320, 448
Go to full version
