Author Topic: HELP!!! Board Problems!!!!  (Read 6307 times)
Mac Green
  • Last login:June 08, 2017, 12:03:59 am
« on: January 21, 2012, 11:40:34 am »
So I got my board in the mail tested it and got weird noises and like no video at all besides some rgb lines HELP!!!
« Last Edit: January 21, 2012, 12:00:25 pm by Mac Green »
Re: HELP!!! Board Problems!!!!
« Reply #1 on: January 21, 2012, 12:02:21 pm »
Lots of info to go off of to troubleshoot over the internet... ::)
Mac Green
« Reply #2 on: January 21, 2012, 12:03:05 pm »
Yah ive tried i relly want to get this working maybe a rom re seat?
« Reply #3 on: January 21, 2012, 12:05:02 pm »
What kind of board? Pine?
[/sarcasm]
Mac Green
« Reply #4 on: January 21, 2012, 12:14:40 pm »
Survival arts sammy SSV system hardware
SavannahLion
« Reply #5 on: January 21, 2012, 12:23:45 pm »
[/sarcasm]
I have a board, can you identify it for me? It has a couple of knots in it and it's about seven feet long and 10 inches wide.
Did you ask Google?
« Reply #6 on: January 21, 2012, 12:36:36 pm »
Is the kanooter valve open or closed?
Mac Green
« Reply #7 on: January 21, 2012, 12:46:13 pm »
funny I really need help guys
« Reply #8 on: January 21, 2012, 12:51:01 pm »
If you really need help, you really need to supply detailed information. Pics help out a lot sometimes as well.
The alternative is to install one of these buttons:
Mac Green
« Reply #9 on: January 21, 2012, 12:56:36 pm »
ok ill post a video and pictures maybe the audio im getting from the board
Mac Green
« Reply #10 on: January 21, 2012, 02:08:00 pm »
OK i got a audio recording and some pictures there all in the ev zip
Mac Green
« Reply #11 on: January 21, 2012, 02:30:04 pm »
the board looks clean imo nothing seems to be missing or fried
« Reply #12 on: January 21, 2012, 02:37:22 pm »
Not sure what exactly you're trying to capture with those pics (besides the one of the monitor). Since you're not going to freely offer up information, I'll try to pry a little bit more out of you.
What cabinet are you trying to run this in?
Has the cabinet had any modifications or conversions done in the past? Are the harnesses visibly altered?
Is the monitor a known good monitor?
Have you had a working game running in this cab? (I assume so, but you never know)
If so, what game(s) have you had running in it?
One thing you will want to do is consult this game's manual and the manual(s) of the working game(s) (if any) and check the schematics, in particular the video signals and audio. Don't be affraid to do some digging.
Mac Green
« Reply #13 on: January 21, 2012, 02:47:07 pm »
Hey thanks for the reply the cabinet is MK2 so standard jamma its running tekken tag and the monitor works flawlessly the harness is labeled so i know i didnt wire it wrong i was just showing the board looked fine and not burned or anything
Mac Green
« Reply #14 on: January 21, 2012, 05:59:56 pm »
OK i reseated cleaned and sanded all the roms and ics plug it in and the same thing
SavannahLion
« Reply #15 on: January 21, 2012, 07:24:23 pm »
Let's clarify the purposes of the pictures. It allows someone, like people on this forum, to look for and identify missing IC's, burnt or damaged traces and so on. One of the key points is that the photo does need to be as clear as possible. Hint: if you can't read the boards identifying marks, the picture is not clear enough. I see a lot of people that insist that they've checked this and that or they've reseated this, or they cleaned that and a well taken photo would reveal something that the person would easily miss. Missing caps. A missing IC in a slot. Mixed IC's.
If you want help, you need to work with us. We're not being ---Deutsche Frankfurters---, but please don't waste our time if you're unwilling to take the steps to get that assistance.
Anyways, from what I can tell from the manual (yes, I Googled for and found the manual. Try it yourself. The manual is not very good but it's a start.), you've got one of those bastard daughter ROM boards which is, somewhat, confirmed by the photos and what looks like quad I/O header connectors. If it's anything like those damn Capcom boards, you might want to check the connectors to make sure there's no damaged or missing pins. I still have a Capcom set on my desk because of that.
Mac Green
« Reply #16 on: January 21, 2012, 07:39:56 pm »
Thanks for the response yes i have the manual ive checked every pin nothing is missing or broken nothing burned this just leaves me scratching my head the board looks new well keep he replys coming and ill keep yall updated
Mac Green
« Reply #17 on: January 21, 2012, 07:49:19 pm »
ok i checked again still every thing is there WTH is wrong with this thing????  :banghead:
Mac Green
« Reply #18 on: January 21, 2012, 09:43:45 pm »
OK the seller refunded me and i get to keep the board free project board
Mac Green
« Reply #19 on: January 23, 2012, 12:13:25 pm »
BUMP!
Mac Green
« Reply #20 on: January 23, 2012, 05:33:08 pm »
really no one?
Mac Green
« Reply #21 on: January 25, 2012, 02:34:23 pm »
Anyone wanna help me?
Kevin Mullins
    • Me on Myspace
« Reply #22 on: January 25, 2012, 03:22:25 pm »
Did you measure power supply voltages while this particular board is plugged in and powered up?
Is your JAMMA harness in the cabinet "keyed" so that the board couldn't be plugged in backwards?
Mac Green
« Reply #23 on: January 25, 2012, 03:25:37 pm »
Yes its keyed and marked ive played a few boards in the same cabinet fine the voltages are the standard +5v and +12v ive reseated cleaned and sanded every rom and ic even the 4 board conecters
« Reply #24 on: January 25, 2012, 03:28:06 pm »
What game is it?
« Reply #25 on: January 25, 2012, 03:28:48 pm »
Mac Green
« Reply #26 on: January 25, 2012, 03:29:01 pm »
What game is it?
Sammy Survival Arts
« Reply #27 on: January 25, 2012, 03:32:06 pm »
Did you check the voltages on the board? Not just coming out of the PS.
Mac Green
« Reply #28 on: January 25, 2012, 03:37:29 pm »
 No im in the process of moving and my meter is packed
« Reply #29 on: January 25, 2012, 04:39:10 pm »
So you're expecting us to come up with the solution out of thin air?
How about you wait till you're properly equipped to attempt to repair this.
Mac Green
« Reply #30 on: January 25, 2012, 05:26:25 pm »
Sounds like you may have moisture in your capacitors.  Try putting the board in your microwave for 30 seconds and see if that dries them out.
wouldnt that fry my board?
Mac Green
« Reply #31 on: January 25, 2012, 07:05:30 pm »
so i used a heat gun on the capacitors and still same thing except the audio is starting to sound clearer
  • Last login:April 30, 2024, 07:38:23 am
« Reply #32 on: January 25, 2012, 07:06:31 pm »
« Reply #33 on: January 25, 2012, 07:13:48 pm »
 :duckhunt
Mac Green
« Reply #34 on: January 25, 2012, 07:20:32 pm »
 :duckhunt
Alright whats up here?
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
« Reply #35 on: January 25, 2012, 07:25:14 pm »
Hey Mac,
 I'm not trying to sound like a jerk, but you really haven't supplied the proper info in order for anyone to help you here.
When posting a problem, you first need to state all of the specs, what the board is, what the cabinet is that you are putting it in, etc.
When posting pics and videos, they need to be of what it is doing wrong, not pics of the board with no wiring to it, those pics don't help.
Theres seems a be a problem on these boards forums where people will post a vague problem and expect someone to know off the top of their head whats at fault.
Then when they are told to do certian first steps, such as meter for proper voltage at the board (not the power supply), they instead take the lazier way of just asking more questions and never following through with what they were told to do.
First steps in board repair: 1) visually check for anything obvious 2) Verify 5v (typically around 5.1v) at the board (best to check right at the power pins on an ic chip) 3)reseat chips and check for bent legs. Some times these chips need to be have the legs cleaned and too darn many times, some legs need to be repaired (new leg soldered on) especially in the case of older boards like Pacman, Galaga, etc.
True, there are some common known problems that can be answered quickly, but more often they can't be answered withou more info.
Mac Green
« Reply #36 on: January 25, 2012, 07:29:30 pm »
Hey Mac,
OK the cab im putting it in is an MK2 running tekken tag the board is survival arts ill get some more pictures when i get a chance sorry if this was vague im new at this and i wanted my board to work thanks Mac
mgb
  • North East, US
« Reply #37 on: January 25, 2012, 07:31:29 pm »
You really need to check the 5v at the board.
also a video of what its doing would really help
Mac Green
« Reply #38 on: January 25, 2012, 07:32:12 pm »
ok im on it now
Mac Green
« Reply #39 on: January 25, 2012, 07:55:48 pm »
heres the link sorry i would upload to youtube my computer just doesnt like to upload to it http://www.mediafire.com/?of9e8l9lvpume0o
