Main > Everything Else
Help with Electronics Repair, where to find the right fuse?
<< < (4/4)
MonMotha:
I've definitely seen bridge rectifiers fail shorted.  Caps too, of course, but probably actually the rectifiers more often.
knave:
I visually inspected all the caps and I didn't see any that looked bad. but then again I'm a noob at such stuff.
I was hoping that I could just pop in a new fuse and poof it works now.
The device failed after a particularly bad surge.
I didn't even know it had a fuse until I cracked it open.
Now I will have to check for continuity since there is no visible damage. (I was kinda hoping to see what was bad.)
lilshawn:
--- Quote from: knave on January 24, 2012, 12:33:10 pm ---The device failed after a particularly bad surge.
I would say the bridge rectifier is knackered then.
a power surge exceeds the capability of the diodes in the bridge...a diode in the bridge shorts and it basically connects the 2 sides of the plug together creating a huge surge of current...blowing the fuse.
you might get lucky and it would have a standard diode bridge and can just swap the whole thing,  otherwise they would have used individual diodes, in which case, you'll have to test each one and find the culprit.
Navigation
[0] Message Index
[*] Previous page
Go to full version
