Author Topic: grossly over estimated the power of my netbook  (Read 1907 times)
Kangum
  • Last login:February 25, 2018, 07:46:20 am
« on: January 14, 2012, 10:19:44 pm »
I bought a hp dm1-4010us 11 inch laptop. it has a AMD-E450 1.65 cpu a AMD 6320 gpu and 8 gigs of ram and a 320 7200rpm hard drive. Ive owned netbooks in the past so I knew what to expect. It was definitely better then an intel atom machine. I thought to myself, what the heck. if i dont like it i can throw it in my pacman coctail. well that isnt going to happen. it couldnt even run castlevania. it was pitiful. I dont know if its because im running 144 or what. the machine wont run 99% of the games. it sucks. I am so disappointed with the machine now. I guess for the 350 i paid for it i shouldnt expect much. but still. sigh.
DaveMMR
    • TeeVee Games
Re: grossly over estimated the power of my netbook
« Reply #1 on: January 15, 2012, 12:17:34 am »
Try using an older MAME version.
Samstag
  • Last login:December 16, 2016, 01:41:19 am
  • That's not a llama!
« Reply #2 on: January 15, 2012, 12:26:38 am »
Yeah go for an older version.  I'm using an ancient ITX Epia board running somewhere around 400MHz and it plays all the classics great.
Kangum
« Reply #3 on: January 15, 2012, 12:30:27 am »
ok i will give it a shot. the only "older" mame set i have is .36 i dont even think coctail flipping was added yet.
BobA
  • What Me Worry?
« Reply #4 on: January 15, 2012, 01:54:54 am »
I use .132 and .139 with Intel atom single and dual cores and most classics play fine and many of the other games such as NeoGeo. The only problem area I have consistantly is when using CHDs although Area51 works well and some of the other less demanding CHDs.
404
« Reply #5 on: January 15, 2012, 10:59:03 am »
Something has to be wrong somewhere. I run mame, snes, genesis/megadrive etc on a flexatx sized pc with the following specs
p4 era celeron 1ghz with no CPU level cache
512mb ddr1 pc3200
40gig 5400rpm drive
on board intel 845i graphics
I can easily play roughly 70% of games without ever touching a single setting.
Something may not be playing well with mame on that machine (no pun intended) Try a different mame derivative, check your cpu load and memory usage.
Cynicaster
  • Last login:June 22, 2021, 12:12:55 pm
« Reply #6 on: January 15, 2012, 11:57:25 am »
 Yeah, something doesn't seem right. My MAME machine is some 7-8 year-old PC with single core and 1gig RAM that I bought used for dirt cheap. It runs the classics like a champ, and even plays some proto-3D games like Tekken and Xevious 3DG no problem.
Kangum
« Reply #7 on: January 15, 2012, 01:35:19 pm »
wow you guys were right. my machine was acting really weird. so i did a minimum factory restore. started up mame and it played every game i tried perfectly. I cant figure out for the life of me what caused my issue before. it kept saying my processor was at 25% use but nothing was listed under task manager. everything was really slow. Im glad I did the restore. Its like a whole different machine. woohoo!
404
« Reply #8 on: January 15, 2012, 01:52:36 pm »
Yeah, that sounds so much better. Something must have been throttling you there. Glad you got it sorted.
Kangum
« Reply #9 on: January 15, 2012, 07:45:04 pm »
Thanks. Its running very smooth now. I tested even more games as some stuff was restored. Neo geo and everything was working perfectly and smooth. I dont know if I had a trojon or what but its gone now. I just hope I dont accidently put back what nerfed my system.
