Main > Main Forum
Joystick Help for first project
starwarsfan54321:
Just to add some clarification, I can only have two joysticks, machine will be using jamma harness for a multiboard.
Thanks for the responses
BobA:
If you are using a multibard then the magstick plus is a good fit for it as most are 4 way games. If you are using a xxxx multiboard then the 2 regular joysticks and 1 dedicated 4 way are still an option as the 4 way is just connected to the same connections as the first 8 way.
Matt Berry:
For me personally I didn't care for the feel of the magsticks. I have tried out a lot of joysticks through out the years, right now my favorites are the Seimitsu LS32 or the Sanwa JLW.
mgb:
If you definitely must only have 2 joysticks because of cp room or something, then maybe the Sanwa Jlw or the Seimitsu is you best choice.
I use the JLWs and I'm very happy with them.
Just to give you some ideas on options: What I have is a Sanwa Jlw for player 1, which has a circle gate (restrictor) so its dedicated 8-way and I use the cherry switches that are typically used in Happ Supers (less clicky). I currently have a JLW for player 2 that has the 4-way, 8-way restrictor but I plan on trying out the Omni2 from Groovy Game Gear which looks like a JLW with a knub on the restrictor for easy switching between 4 and 8 way.
Remember, with switchable sticks, you will need to access underneath for switching, unless you use the magstik plus. Personally I have heard a lot of complaints about that stick, but everyones taste is different.
wizkid32:
I am using Happ Super Joysticks for my project. You should consider them. (I think they are better than the Competitions)
