Main > Everything Else
Question about up-to-date AGP video cards.
<< < (2/2)
ark_ader:
You should get a ATI 9550 pretty cheap.  That should work for you Howard.  I'd send you one but all mine are PCIe.
Howard_Casto:
--- Quote from: ark_ader on December 26, 2011, 09:54:09 am ---You should get a ATI 9550 pretty cheap.  That should work for you Howard.  I'd send you one but all mine are PCIe.
LOL nope..... pretty sure the 9x series is what's in there now.  It only supports as high as shader model 2.0, all the latest emus need 3.0.
404:
last card i saw that was agp was a nvidia geforce 8400. On the same token, you can probably find yourself a second hand motherboard that supports your cpu and hard drive that has a pci-e slot for next to nothing these days. New AGP cards tend to be sold at a premium these days. By the time you get one, you would almost incur the same costs as a compatible pci-e motherboard.
knave:
$43.00
HIS H435F512HA Radeon HD 4350 512MB 64-bit DDR3 AGP 4X/8X HDCP Ready Low Profile Ready Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161318R
Edit: This one is now out of stock but there are other comparable cards in the $50 range. Just try one.
Gray_Area:
--- Quote from: knave on January 06, 2012, 12:07:14 pm ---$43.00
Noot any-more. I'm seeing 2.8ghz HT mobo PCs on CL for under a hundred dollars (although, I think they're still too much). I'd upgrade. Do as Arby says: donate your old one to the proles. No, seriously, sell yours and upgrade.
Navigation
[0] Message Index
[*] Previous page
Go to full version
