Author Topic: Anyone have a ATI 4650 512MB PCI-E ?  (Read 1007 times)
jimmy2x2x
« on: December 16, 2011, 12:16:07 am »
Im thinking of changing my cabs gfx card to a 4650, but am a little unsure of its capability.
Cab is c2d 2.2ghz, 2gb, xp x64, currently with a 8800gtx (is the 4650 comparable to the gtx?)
Main reason for changing is to support Groovymame, anyone running it on one of these cards?
Can the card run demul 640x480 and streetfighter iv (pc version 1024x768) at full detail, full 60fps speed?
Anything not run well on this card or any other caveats I need to be aware of before purchasing?
Drnick
  • Last login:May 06, 2023, 01:19:48 pm
  • Plodding Through Life
Re: Anyone have a ATI 4650 512MB PCI-E ?
« Reply #1 on: December 16, 2011, 05:35:33 am »
Nope, not got a 4650 but according to Toms Hardware the 8800 performs better :-) Try an ATI radeon 4850
dmarcum99
  • Last login:January 21, 2020, 12:02:36 am
« Reply #2 on: December 16, 2011, 09:31:16 am »
Believe it or not, the next card up in the series blows the 4650 away...try to snag a 4670....or go as was suggested with the 4800 series.
If you're set on the 4650...here's a fanless model:
http://www.ebay.com/itm/350454215362
« Last Edit: December 16, 2011, 09:37:58 am by dmarcum99 »
Grimoz
  • Last login:August 06, 2018, 02:11:22 am
« Reply #3 on: December 18, 2011, 10:34:47 pm »
Ive got a 4670 and its very good.
jimmy2x2x
« Reply #4 on: December 19, 2011, 12:52:36 am »
4670 Looks like a much better option, thanks for the heads up
Anyone know how it performs in:
Groovymame (looks good as its listed on the gm site)
Demul
Street Fighter IV (pc version)
Mames HLSL
Taitio Type X games
I would imagine that it should work fine, but would like some confirmation if anyone has tried it on the above
Jollywest
  • Last login:April 09, 2024, 01:37:27 pm
« Reply #5 on: December 19, 2011, 01:58:34 pm »
I have been using a 4650 512mb and a 4670 1GB (as well as a 4550) and although I've never tested it on the items you mentioned. I did test it on the new Supermodel 0.2a Sega Model 3 emu and Elsemi's Model 2 emu. The 4670 ran about 5fps faster than the 4650, nothing too spectacular but with it running Daytona 2 at 58fps rather than 53fps it made a big difference to the original arcade feel of the game, plus I snagged the 4670 cheaper than the 4650 from eBay.
lettuce
  • Make It So!
« Reply #6 on: December 19, 2011, 02:54:53 pm »
Does a HD4850 perform better than a HD4670?
Jollywest
« Reply #7 on: December 19, 2011, 03:23:52 pm »
According to the following site yes;
http://www.videocardbenchmark.net/high_end_gpus.html#
GD3 Mark:
4850 = 1,333
4670 = 759
