Main > Main Forum
Picked up my second cabinet...
Pages: << < (2/2)
bkenobi:
Spray that crap with a bleach based cleaner ASAP.  Don't take a chance of the spores getting into your HVAC system and spreading throughout the house!
The price is ok (perhaps a bit high for the cab itself), but if the marquee is in good shape, that makes it worth $10 on it's own.  Not sure what I would do with the cab myself.  With the mold situation and my wife allergic, I'd never be able to bring it home.
jennifer:
            Take the best side clean it up, patch it, then use it for a template to cut 2, Then replace the bottom with new wood.
  It"s lots of work.... but that"s what Jenni would do.
theredlineboss:
--- Quote from: bkenobi on December 15, 2011, 11:21:49 am ---Spray that crap with a bleach based cleaner ASAP.  Don't take a chance of the spores getting into your HVAC system and spreading throughout the house!
Believe me, that was the first thing I checked off my "to do" list - I wasn't quite expecting to find that much mold in it (though it makes sense).  The stuff cleaned off easily with some bleach water.
As far as the cab goes, I figure that this will be good practice for when I redo the Taito cab (which is seen in the first pic).  I have never worked with MDF or particle board, so there won't be much to lose if I mess this up.  I'm quite certain that the damage to the machine would have caused it to be sledgehammer fodder for most people.  :P
-Rob
theredlineboss:
Just thought I'd drop in a quick update, to indicate that I think I may have saved it.
Stripped of it's woodgrain & cut down 6.5 inches:
New wood!
And a closeup of the repaired section (front panel is just sitting there @ the moment):
I'm quite pleased & look forward to working on a somewhat more solid frogger!  I'll start a regular build thread going in the "projects" section when I make some notable progress. :D
-Rob
Mac Green:
Lookin good keep up the good work  ;D
Pages: << < (2/2)
Go to full version
