Main > Main Forum
Hyperspin and Configuration Help Needed!
Pages: << < (2/2)
BadMouth:
--- Quote from: honkey on December 12, 2011, 12:12:47 pm ---Problem Number 2-
NullDC- It has been a few weeks since I gave up on trying to configure NullDC but now I am refreshed and ready to retry. Does anyone have a tutorial on how to set it up that is easy to follow? I was having missing messages popping up and google searches for the files was doing no good.
You'll have to be more specific about what messages are popping up.
RULE #1 - UPDATE YOUR DIRECT X AND VISUAL C RUNTIMES!
http://code.google.com/p/nulldc/
honkey:
--- Quote from: BadMouth on December 12, 2011, 02:43:53 pm ---
Just checked. I am missing two plugins. Is it against forum policy to ask where to get those?
BadMouth:
I posted the link to the nulldc page that has the links to the runtimes.
If you're missing NullDC plugins, you should be able to find them on the NullDC google code site.
If you're missing the bios files.......those are the same as roms.
honkey:
All right, I put NullDC on hold because I am getting frustrated with it. It appears that I need Directx9.0c and I have 10.1.
I am trying to configure Hyperspin with NES and SNES also and when I run the emulators without Hyperspin, the roms work fine. However, when I run it with Hyperspin it says no file is found. All of my roms have "(U)" for United States, and Hyperspin is searching for "(USA)" and sometimes more than what I have the files saved as. Is there a quick way to fix this without clicking on each individual file and changing the names for all 1,000 roms?
Drnick:
Yes, use Hyperspin rom manager, load the XML for Nes or Snes whichever you want to use and then you can rename the roms with the correct naming convention.  Its pretty good about getting it right.
Pages: << < (2/2)
Go to full version
