Main > Main Forum
Cabinet choices
Pages: << < (3/3)
amendonz:
A
wizkid32:
I'd go with B.  It has a nicely large control panel, two coin doors, and the marquee is lit w/ a standard Florescent/LED strip.
iconone:
I think I'm going to go with C. It looks like it is in the best shape out of the 3. The guy said he would throw in a power supply and jamma harness along with the cabinet. Thanks for all the input and y'all will see a lot more of me.  :burgerking:
bkenobi:
--- Quote from: iconone on December 07, 2011, 09:33:01 am ---The guy said he would throw in a power supply and jamma harness along with the cabinet. Thanks for all the input and y'all will see a lot more of me.  :burgerking:
Which will help with...  The cab is gutted (no monitor, no controls).  You won't use the JAMMA harness and the power supply is of little use.  I guess you can put it up on B/S/T?
I'd go with A, but metal CP's are something that look complicated to work with when modifying (even though they look WAY better).  If a blank were available, metal would be a no brainer for me!
Blanka:
Go with A. It looks coolest and B and C are too much Mame-machines with floppy cantilevering wide wing CP's. CP's belong within the cab, not outside.
Pages: << < (3/3)
Go to full version
