Main > Main Forum
MameUI64 Zaxxon analog joystick
Pages: << < (2/4) > >>
BobA:
Can you give any details?   What controller is it going to and how is it wired?
jcutler0902:
Thanks for the help. I have that 8 way Joy (see link above). It is wired to an Ipac 4 and connected to the 4SW 1-4 for the directions a d 5&6 for the trigger buttons. From what I understand if you use Mame (non GUI)' you can hit tab to make changes to the controls. Since I am currently using MameUI64, that is not an option here.
Let me know what other info I can provide.
JC
BobA:
Using mame UI you can still make changes on a per game setting.   Just hit tab when you are in zaxxon and the menu will come up.
jcutler0902:
I have tried that and tab does nothing. I know it will allow you enter control setup, but for some reason it will not allow me to now.
BobA:
Sounds like your tab key may have been reasigned.  If you delete default.cfg it will bring you back to the original settings and tab should work.  It is in your cfg directory.
Go to full version
