Author Topic: Control panel width  (Read 6027 times)
GregD
  • Last login:December 17, 2015, 02:26:41 pm
    • Arcade Nebula
Control panel width
« on: October 25, 2011, 07:51:12 pm »
Just wondering what you think the minimum width would be for a two player control panel with six buttons per player and a 3 inch trackball in the middle?   I want it to be comfortable for two players but I also want to fit the controls within the cabinet and not have the shelf type that is wider than the cabinet.   I am working with a 19“ lcd so I can't make it too wide without the monitor appearing way too small with a huge bezel.   Thanks for your input.
wildclay
  • Last login:May 20, 2013, 11:07:21 pm
Re: Control panel width
« Reply #1 on: October 25, 2011, 08:56:24 pm »
Hi GregD,  I am no expert at determining an ideal length for a control panel with regard to the monitor size, but ultimately it will end up coming down to personal preference.  A good reference for size might the 2-player panel from Mameroom.com. It has room for 6-7 buttons, as well as a trackball in between. Their panel is 35" wide. The links below show the full dimensions:
http://mameroom.com/Products_Classic_Kit.asp
http://mameroom.com/Products_ClassicController.asp
I don't have their 2-player panel, but I bought their 4-player quad panel (48" wide) and I think it fits 4-players comfortably. Hope this helps!
gilby4runner
  • Last login:October 05, 2012, 10:27:16 am
« Reply #2 on: October 25, 2011, 09:30:29 pm »
Check out my defender build in the project section.  One if the members here designed a panel for me with 2 players and a trackball.  I want to say my panel is 24 inches wide.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: October 25, 2011, 09:39:49 pm »
It can't be done without either really cramped controls or a huge bezel around the monitor
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #4 on: October 26, 2011, 06:08:15 am »
This is my 2P 7button + 3" trackball layout crammed into 24":
It can be done, but it's pretty tight. I cannot imagine it being any closer.
Donkbaca
« Reply #5 on: October 26, 2011, 09:28:03 am »
How wide is that screen? 15 inches? At 24 inches you are looking at a bezel that is 4.5 inches on each side.
  • Last login:Yesterday at 09:56:41 pm
« Reply #6 on: October 26, 2011, 09:59:46 am »
24" for a 2 player "street fighter layout" sans track ball, its what I did on the NeoMAME machine (using the spacing already there for a 2 player neogeo 4 button layout converted to 6 button lay out. Players are close, not cramped, cant imagine squeezing a trackball in there, and thats with a 25" arcade monitor.
t3design
  • Last login:January 13, 2024, 07:19:01 pm
  • Orange Power! Go Pokes!
    • Cowboy Arcade Project
« Reply #7 on: October 26, 2011, 10:15:38 am »
That was me. I just tightened up my panel which is 27":
Cowboy Arcade Project ThreadCowboy Arcade Project Website
If you are an obsessive/compulsive pyromaniac, you better make sure you wear flame retardant pajamas.
monkey puzzle
  • Last login:March 23, 2024, 02:11:59 pm
« Reply #8 on: October 26, 2011, 12:58:27 pm »
I didn't want a cp wider than the cabinet either, so I had the same problem as you although I'm using a 22" widescreen LCD monitor.
The cp is 660mm wide (26") I think this is just about adequet width for 2 players but I think it would start to get a bit cramped if any smaller.(I'm going to fit a spinner instead of a trackball)
The border around the monitor is 3 3/4" thick which isn't too bad but I wouldnt want it any bigger.
I think I got the balance about right. You can't have it exactly the way you want it unless you get a larger monitor which starts to get expensive.
