Author Topic: pga golf vr-gobal  (Read 254492 times)
stpcore
  • Last login:February 09, 2019, 05:48:56 pm
Re: pga golf vr-gobal
« Reply #920 on: February 16, 2013, 12:35:57 pm »
Thanks Ed.  Not sure if it needs to be cleaned because when PGA boots up I get the error message.  When I go into the PGA computer I can see the card in Device Manager so not sure what to do next.
Offering commercial grade vinyl decal printing for cabinet side art, control panel overlays, monitor bezels, marquees, etc.
ed12
« Reply #921 on: February 16, 2013, 12:43:39 pm »
hi
u have a bad hexcsum in the main file's
>>gobalvr<<
a few q's are in order here
was this a copyed h/d ?
was it a used h/d ?
is it the orignal h/d to the game ?
if a copy ? did u propley prepare it ?
these are q's i need the answer's to
i know it sound's long but there is a reason for my madness,follow along for now
attached is the cypress chip set
ed
stpcore
« Reply #922 on: February 16, 2013, 12:48:08 pm »
This is the original Team Challenge HD that came in the original PGA tower.
ed12
« Reply #923 on: February 16, 2013, 01:06:11 pm »
hi
ok that answer's alot
did u re-load it ?
if so with the orignal s/w ? >there is a reason for that question<
is the reader the orignal ?
as the usb olny came in later rev 3.5 and 4
before that it was a serial unit
u can tell by the open port on the i/o board
where the reader would plug in
then the mfg of the board went up a rev and fourced all to the usb side of thing's
and that is where it get's stickey
if u are using a 4 port usb card
get rid of it with rev 3.5/4 as it is not needed
3.4 require's it as it is the change over s/w
the patch is 4kb or such
and is junk and  i will not even post it
if it is a early rev of the game
>menu/game-setup/rev<
dongle will tell u really what it is >3/3.4/4< canada/usa
in the usa it is a sub like 4.5 or 3.7 or such
if u do not have the proper dongle it will give u card reader error's
hence the reason i moved to ditch it
now u can c where my question's are going
read the post over a few time's
DO NOT SKIP A POINT
ed
stpcore
« Reply #924 on: February 16, 2013, 01:12:15 pm »
Well the tower I have does have 4 USB ports but they are in separate locations (two on the bottom and 2 in the upper portion of the computer).  Do you think I should reinstall the game?  I don't mind doing that but it will be depressing losing all of our stats and scores.  Thanks for taking the time this afternoon to help!
ed12
« Reply #925 on: February 16, 2013, 01:26:50 pm »
hi
hmm cant ever rem seeing a 2 port pcima card ?
they come as 2/4/6/8
but we used 4 port
the 2 on the back of the tower are usb 1
the card is for faster reading usb2
but for all intensive reason's is usless to us as the i/o mfg never fully coded into it
ie >usb2< they stuck with >usb1<
hence the reason i tell ppl to ditch it
now u got this tower as a complete running unit ?
with it's proper disk's ?
if so how many less the rescue disk ?
and on the rescue disk EXACTLEY what is printed COMPLETLEY
this way i can ref my libary and tell u what reader/i/o/usb config u should have
as from what u are telling me from what i can deduce to date is u bought a running unit,did u get the origanl card reader?
if not please tell me the s/w rev..the rescuse disk will do that for me
ed
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #926 on: February 16, 2013, 01:53:42 pm »
Hi Ed,
Can you please send my tower back and let me know how much I owe you for the repair and return shipping? Im chopping at the bit to play some golf.
Sent from my SGH-T989 using Tapatalk 2
WANTED: NINTENDO CABINETS WORKING OR NOT
ed12
« Reply #927 on: February 16, 2013, 03:19:04 pm »
hi
dirt i did send it
it came back !!refused!! by your homeland ppl
my boss is going usa bound this week some time i will have him take it over as he can travel back and fourth..it's about that simple
ed
stpcore
« Reply #928 on: February 16, 2013, 04:12:38 pm »
hi
but we used 4 port
ed
My mistake Ed.  It looks like I have two USB ports toward the top and one USB port towards the i/o card under the VGA port.
ed12
« Reply #929 on: February 16, 2013, 04:41:02 pm »
hi
from your pic i c 2 usb's on the tower
this make's it rev 3/3.5 era
from the lower part of the pic i c 2 usb card's?
as a rule i run the i/o usb right into 1 of the tower's usb port's >unless they are trashed<,at which point i will ditch the mobo
as it will give problem's in a short date of time
plug the card reader right into 1 of the tower's port's
it should pick it right up after a reboot
if not test the port's
:bios: make sure they are enabled
because if they are out so is the conxit chip set
the t10 >lan< should also be enabled
and u should as pre 1 of my post's beable to goggle with the putter
if not !!!!trash the board!!!,i can not get any clearer
from your pic i see wrong routing
is the i/o plugged into another usb card ?
if so u are confiliting the interuptes
the i/o card is ment to plug into a usb port on the tower :main usb's: not a usb card
as it's input call's are usb1 based
usb2 is simply to fast for it
live un-plugged i cannot touch on..it's a hack of it's gamming >dealer here<
about the same with silver strike/buck hunter about anything expect for pre gt-live
before that i have full okie dokie
ed
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #930 on: February 16, 2013, 05:07:09 pm »
Hi Ed,
Can you please read my last post n help with my betabrite prob if ya can mate?? Where's the love?? Ha ha ha
Thx Spitfire
stpcore
« Reply #931 on: February 16, 2013, 05:12:20 pm »
hi
ed
So I reconnected the USB per your instructions and the card reader error still shows.  When I go into BIOS the USB ports are enabled.  So you think it's not a driver issue?
dirt
Re: Re: pga golf vr-gobal
« Reply #932 on: February 16, 2013, 05:24:54 pm »
hi
dirt i did send it
ed
that sucks they returned it. I guess its that homeland security bull$#!+. If your boss can bring it over and send it that would be great. My son has been driving me nut about wanting to play golf with me. He is autistic so he obsesses sometimes.
ed12
« Reply #933 on: February 16, 2013, 09:27:19 pm »
hi
dirt it is
u are not the olny 1 and won't be the last
crap i have a hard time getting part's in-bound without your fine ppl going through them,i once had an order come in the back-glass was cracked
note said :opp's: sorry homeland idiots
xlink/dallas/maxuim/ic-core will not even chat me any more
again thk-u home land idiot's
all over me taking a hit for my wife over 2 joint's
30 odd year's ago
ed
ed12
« Reply #934 on: February 16, 2013, 09:29:38 pm »
hi
stpcore
 that look's like a driver issuie
exactley what rev are u running there ?
ed
stpcore
« Reply #935 on: February 16, 2013, 10:04:57 pm »
hi
stpcore
ed
The card readers aren't working on my "Challenge" tower either as I get then "No Card Reader" error upon boot. Any idea where an can order a couple replacements? I'm thinking they may just be bad for some reason.
ed12
« Reply #936 on: February 16, 2013, 11:09:43 pm »
hi
i repair them
but i do not another trip like the 1 i am going through with dirt >no fault of his<
if u can rewrite the chip's ? i can give u the code
it's a easy post
if u did the test's i requested today
your reply would would be more like i did them test's and still no go
with it comming up not seeing the device's, but xp dose tell's me driver's were kicked or they are not made for the rev of the s/w,these are very finckey set of driver's.....
<xs:schema id="XmlPlayerRegistration" xmlns:codegen="urn:schemas-microsoft-com:xml-msprop" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:sql="urn:schemas-microsoft-com:mapping-schema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
   <xs:element name="PReg" codegen:typedName="PlayerRegistration" codegen:typedPlural="PlayerRegistrations">
      <xs:complexType>
         <xs:sequence>
            <xs:element name="UI" codegen:typedName="UserCardID" type="xs:int" />
            <xs:element name="F" codegen:typedName="FirstName" type="xs:string" />
            <xs:element name="L" codegen:typedName="LastName" type="xs:string" />
            <xs:element name="S1" codegen:typedName="Street1" type="xs:string" />
            <xs:element name="S2" codegen:typedName="Street2" type="xs:string" minOccurs="0" />
            <xs:element name="CT" codegen:typedName="City" type="xs:string" />
            <xs:element name="S" codegen:typedName="State" type="xs:string" />
            <xs:element name="Z" codegen:typedName="PostalCode" type="xs:string" />
            <xs:element name="C" codegen:typedName="Country" type="xs:string" />
            <xs:element name="R" codegen:typedName="RegionID" type="xs:int" />
            <xs:element name="EM" codegen:typedName="Email" type="xs:string" minOccurs="0" />
         </xs:sequence>
      </xs:complexType>
   </xs:element>
</xs:schema>
so as u can clearly see
it is called from more then 1 spot
btw ppl if u know vb??
that there is YOUR PLAYER CARD KILL RUN CMD IN vb
ed
ed12
« Reply #937 on: February 16, 2013, 11:14:00 pm »
hi
as ulgy as this sh&it is..very lose code
>player's-board-code-from-pga-to-sign< again in vb
<xs:schema id="XmlLeaderBoard" xmlns:codegen="urn:schemas-microsoft-com:xml-msprop" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:sql="urn:schemas-microsoft-com:mapping-schema" xmlns:msdata="urn:schemas-microsoft-com:xml-msdata">
   <xs:element name="NLBoard" codegen:typedName="NationalLeaderBoard" codegen:typedPlural="NationalLeaderBoards">
      <xs:complexType>
         <xs:sequence>
            <xs:element name="TI" codegen:typedName="TourneyID" type="xs:int" />
            <xs:element name="NE" codegen:typedName="NationalLeaderBoardEntry" codegen:typedPlural="NationalLeaderBoardEntrys">
               <xs:complexType>
                  <xs:sequence>
                     <xs:element name="UI" codegen:typedName="UserLoginID" type="xs:int" />
                     <xs:element name="C" codegen:typedName="City" type="xs:string" />
                     <xs:element name="ST" codegen:typedName="Stroke" type="xs:int" />
                     <xs:element name="GS" codegen:typedName="GSP" type="xs:int" />
                     <xs:element name="LD" codegen:typedName="LongestDrive" type="xs:int" />
                  </xs:sequence>
               </xs:complexType>
            </xs:element>
         </xs:sequence>
      </xs:complexType>
   </xs:element>
   <xs:element name="CLBoard" codegen:typedName="CabinetLeaderBoard" codegen:typedPlural="CabinetLeaderBoards">
      <xs:complexType>
         <xs:sequence>
            <xs:element name="CE" codegen:typedName="CabinetLeaderBoardEntry" codegen:typedPlural="CabinetLeaderBoardEntrys">
               <xs:complexType>
                  <xs:sequence>
                     <xs:element name="R" codegen:typedName="Rank" type="xs:int" />
                  </xs:sequence>
               </xs:complexType>
            </xs:element>
         </xs:sequence>
      </xs:complexType>
   </xs:element>
</xs:schema>
enjoy
ed
ed12
« Reply #938 on: February 16, 2013, 11:20:24 pm »
hi
bad word's .txt which is a .ini once tunred on
>bad word's<
anoint
approach
ass
---uvula---
avuncular
bastard
bent
---smurfette---
Blowjob
bud
bulge
burgle
butthead
chum
cleft
clitoris
clog
cloister
cock
---Bad words, bad words, whatcha gonna do? Whatcha gonna do when saint censors you?---
cornhole
cornholio
crampon
cranny
Crap
crap
croce
cum
cunnilingus
dangle
defecation
dip
discharge
dongle
---meecrob---
Dukakis
dyke
encroach
extrude
fart
fellatio
feltching
flow
fluid
foist
---fudgesicle---
---smurf---
gaping
genitalia
gleatinous
gnaw
gramps
gravy
gush
handle
heap
ho
hoist
Hole
homo
horny
hotpocket
juice-box
knob
labile
lacrimal
leakage
load
loaf
lube
lump
masturbation
meal
membrane
moist
notch
nugget
onus
paginate
papal
penis
pentile
perturb
pester
Phuck
pilaf
pile
piss
plug
plump
plunder
poke
---tallywhacker---
proctor
prong
pucker
puny
Puss
putty
queer
ramp
receptacle
rictus
rimjob
rub
---steaming pile of meadow muffin---
shittie
---smurfy---
slab
slat
---stingray---
snack
snicker
snorkel
snout
sodomy
Sophocles
spackle
spake
spectate
spew
spic
spill
spray mount
spread
spunk
squirt
stew
stew
stuff
stump
subpoena
Suck
supine
tang
thick
tit
tutelage
urination
usage
vagina
vascillate
wet-exit
whack
Whore
wipe
allowed word's
same .txt or .ini
Trude
Sage
Fanny
Esther
Asta
Dana
Ha
Tana
Truden
Jane
Kate
Heather
Dan
Han
Peter
Ector
Angus
Hans
Mick
Nick
Dick
Chun
Bill
Sander
Tano
Gage
Victor
Floris
Lane
Patrick
Doncker
Wolfart
Reynout
Redrick
u can move bad into good
simple if u know how to "edit"
ed
stpcore
« Reply #939 on: February 16, 2013, 11:42:13 pm »
Ed, I did every test that I could understand that you requested and nothing worked.  I tried the card readers in another tower to see if it would solve the problem and it didn't.  I can check to see what version of Team Challenge I am running tomorrow.  Thanks for taking the time to help on this.  Have a good night.
Spitfire
« Reply #940 on: February 17, 2013, 01:03:41 am »
Hi Ed, it seems mate u have finally lost it with ur bad words post ha ha ha ha
Please send to Oz what ever u r on? Lol
Just a quickly again where do I place the betabrite.bin file u uploaded on my PGA?
Thx Spitfire
ed12
« Reply #941 on: February 17, 2013, 07:23:29 am »
hi
spitfire
that is the actual bad word script..ie forbidden
unless u add them to the good word's script
see my point ?
the .bin i up-loaded is for the actual sign,so u can edit the .bin and reload it to the eprom of the sign
the c++ code is the driving code for the sign
ed
Spitfire
« Reply #942 on: February 17, 2013, 06:14:58 pm »
Hi Ed,
Ahhh ok my sign just displays betabrite advertising but now PGA stats ads etc. it doesn't even see the sign diagnostic test. Lilshawn is sending me a new cable to see I that makes a difference? Do you think I don't have the drivers on my version of team challenge or do u think the cables the issue?? Or do you have another reason why I'm having this issue?
ed12
« Reply #943 on: February 17, 2013, 09:48:08 pm »
hi spitfire
stay with the new cable first
that way when i up-load the rest of ledbright
stuff u will be in a better posistion to us it
ed
Spitfire
« Reply #944 on: February 18, 2013, 06:49:24 am »
No prob Ed awaiting the new cables arrival and ur go ahead. Have lots to do anyway as I have just started my virtual pin mods to make it come alive and have a number of multicade cab builds on the go.
ed12
« Reply #945 on: February 18, 2013, 02:04:35 pm »
hi
i will be to pull the ledbrite flash
tommrow when i bring home that honking p.s
ed
stpcore
« Reply #946 on: February 20, 2013, 10:33:24 am »
Ed,
Without having my original install disks for Team Challenge what is the easiest way to find out what version I'm running to help us identify the proper drivers for the card reader?
ed12
« Reply #947 on: February 20, 2013, 12:34:15 pm »
hi
stpcore
the dongle speaks a volume to me
short of that the rescuse disk that i sharded is 1 of the 1 disk fit's all
kind of thing
ed
stpcore
« Reply #948 on: February 20, 2013, 12:35:58 pm »
OK, so is there info I can relay to you from the dongle?  I'm not following, sorry.
Also, that Rescue disk you uploaded to Dropbox a while back was incomplete as it was only 8mb in size.  The Rescue that I have up there now is from an original Rescue from Team Challenge and is complete.
« Last Edit: February 20, 2013, 12:39:13 pm by stpcore »
ed12
« Reply #949 on: February 20, 2013, 01:33:49 pm »
hi
sorry about that i thought it was the complete 1 ?
if u open the dongle up
there is boat load of number's on a few of the chip's
write these down and e-mail them to me
i can find your build from that info
as i need to take it the olny thing writtin on the outside of your dongle is :usa:
dirt
e-mail me please
my boss is going to do it for me
so i can give u the info shortly
ed
dirt
« Reply #950 on: February 20, 2013, 01:58:31 pm »
Hi ed,
what is your email adderess?
ed12
« Reply #951 on: February 20, 2013, 03:06:49 pm »
edwarddowney@hotmail.com
ed
dirt
« Reply #952 on: February 20, 2013, 03:30:35 pm »
I just sent you the email ed.
stpcore
« Reply #953 on: February 20, 2013, 07:09:47 pm »
The outside of my dongle says:
H4 M1  5.0
EMMMQ  204883
Don't really see how to decase the dongle and it makes me nervous to try because if I damage it it's going to cost me $139 to have it replaced by Global VR until the dongle bypass is released.  Does that help at all?
ed12
« Reply #954 on: February 20, 2013, 08:58:19 pm »
hi
stpcore
ya
>H4 M1  5.0<
rev 5 software
the lastest for usa
we stopped at 4.5
easy as it get's canadian=odd
usa = even
so with that info in hand your card reader should be usb style
no light's xico mo1002 >v< = verison 84 or higher
u should have a 20 pin dip in place of the 40 pin atmel mirco
your drivers's should be on disk 1 and three
these do not need an enabler so there should not be any on your rescue disk
let me chk my 1-4's and find them for u
ed
dirt
« Reply #955 on: February 20, 2013, 09:06:19 pm »
Hi Ed,
 I forgot to ask, were you able to get my card reader working with my tower?
fg5736
  • Last login:March 02, 2013, 10:30:26 am
« Reply #956 on: February 20, 2013, 09:21:58 pm »
Hi Ed,
I have come across some PGA towers and am looking to move forward and update them.  I know you have been working extremely hard in getting software ready to release so we can truly unlock the potential of these games.
Can you give us an update on where things stand please?  I was reading a bit here and it seemed like things were just about ready, but maybe I was mistaken.  Thanks in advance, and a bigger thank you for your time, expertise, and dedication on this project.  Hope to hear soon.
ed12
« Reply #957 on: February 20, 2013, 09:53:31 pm »
hi
dirt yes it is a complete game,plug and play,enjoy
 fg5736
un-named the proffer for me is just fixing a bug i found
the nick found a few more in the trace route
so from the last piece of up-date the nick was thinking the latter part of this week
what ppl have to understand to test the code it must be loaded and used
and if there is a bug u re-format fix and do it over again,glad it is that nick doing it
as i would have smashed something by now
but i know the nick's work as we have worked toghter in far move complex problem's then this,un-named even laughed at me when i said i have this h-key issuie,until the trace route found the full bug.
and as i said i will not realse s/w that will give and or could be blamed for damaging anything...
ed
dirt
« Reply #958 on: February 20, 2013, 10:06:18 pm »
Thanks Ed, your the man!
fg5736
« Reply #959 on: February 20, 2013, 10:18:46 pm »
Ed,
Thanks.  I understand about the bugs...glad to hear that you aren't going to release something that will crash and cause us all grief.  We all probably would be smashing something ;D. Looking forward to hearing the good news and we will be ready to download very soon.  I'll keep checking here.....thanks!
