Author Topic: Sony Wega Flat Screen  (Read 1590 times)
LASmith132
  • Last login:September 10, 2013, 10:20:56 pm
« on: October 01, 2011, 12:31:56 pm »
I have a Sony KV - 32FS100 - 32" CRT TV. It has a flat screen on it.
in your wise opinion would you think that would work well for an arcade? it has a s-video connections.
  • Last login:May 09, 2023, 01:16:55 pm
Re: Sony Wega Flat Screen
« Reply #1 on: October 01, 2011, 01:16:07 pm »
It could - I just got rid of a 29" one, due to the extremely heavy weight to the thing.  I had tested it to make sure it automatically comes up in the proper setting (S-Video) and it looked really good.  I've since changed and decided to go with a 28" LCD.
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
« Reply #2 on: October 01, 2011, 04:35:02 pm »
It could definitely work but if its the flat crt type, those things are heavy so secure it well.
MonMotha
« Reply #3 on: October 01, 2011, 08:39:03 pm »
Most WEGAs have component connections, I thought.  When set properly and the signals properly generated, this can look essentially arcade perfect.  It'll take a little setting up, but the WEGAs are quite nice monitors, actually, and finding a 32" 4:3 set these days is quite difficult.
S-Video can look pretty darned good, but properly generating S-Video signals from a PC is darned near impossible due to poor design of the PC hardware (hint: the S-Video output on your video card will probably look like crap no matter what you do).
GCS
  • Last login:August 09, 2021, 01:15:28 pm
« Reply #4 on: October 01, 2011, 08:55:00 pm »
Exactly on this comment.
And the other comments are spot on, these things weigh a TON!
My sister has an old 36" to ditch (looks great though) I was considering getting for a shooting cab idea (hey its free) but it is about 250lbs of dead weight.  That is just too much.
It's a shame as it would have been perfect and it would be free.
Greg
mgb
  • North East, US
« Reply #5 on: October 01, 2011, 09:02:39 pm »
Doesn't that Wega also have component. Couldn't that be used with an adaptor
