Main > Software Forum
daphne
Jakobud:
Hey RacerX! How are you playing Dragons Lair II with Daphne? It's not supported with it yet...did you write you own driver for it?
Jakobud
RacerX:
--- Quote ---Hey RacerX!
gnateye:
does daphne support macs?
StephenH:
It might be better to buy the DVD-ROM from Digital Leisure (DO NOT GET DVD-Video, it will not work). Then, use the DVD2Daph utility to create a framefile and convert the audio to Ogg Vorbis.
This is proven to work with daphne.
Frostillicus:
One more thing to think about is: are you going to use a real scoreboard with daphne? apparently they only run under 98 and linux :( I found this out after I took a few evenings wiring up a homebrew one, only to find my xp machine doesn't allow direct control of the parallel port. d'oh!
So it's either 'goodbye scoreboard', or 'hello 98/linux' for my dedicated cabinet(yet to be built).
If you actually own the discs, why wouldn't you just rip them yourself? Daphne has some good step by step instructions with mpegs.
