Main > Main Forum
Hyperspin Wheel Text Overlapping
Pages: << < (3/6) > >>
pinballwizard79:
--- Quote from: Grimoz on September 26, 2011, 06:21:25 pm ---Something else you can try, If its not already set hyperspin to run at the same resolution as your desktop in hyperhq.
Good idea but its already set up that way  :'(
danrosenstein  check out the attachment on the very first post, I think its what you are talking about.
danrosenstein:
You are correct - exact same issue. i didn't catch it from the description, but the attachement makes it clear!
Grimoz:
Out of curiosity what is the text underneath the top layer, is it the same text or is it something different? Also what model is your video card?
pinballwizard79:
--- Quote from: Grimoz on September 27, 2011, 02:02:47 am ---Out of curiosity what is the text underneath the top layer, is it the same text or is it something different? Also what model is your video card?
Under the text would be the text from the previous game & so on, each title compounds!
I have tried the onboard GPU from my brand new ASUS MB (cant recall the model & I am at work now) + used a Galaxy - NVIDIA GeForce 8400GS 512MB DDR2 PCI Express Graphics Card + a bad ass $200 GTX 460 heater of a card too = same ---steaming pile of meadow muffin--- problem.
I used onboard on a bad ass MB (not sure of model) & had no issues with either the onboard or the 2 same GPU's itemized above.
Remember... the current MB & all GPU's work on Windows 7 & a hacked MCE so its mos def not hardware related. Thank god I have like 3 rigs & every OS known to man to eliminate each possibility.
There is something "packed" into certain windows versions that a few of us are missing & I cant wait to figure out what it is because for now I have to clone my personal HD just to play pacman FML.
Jammin0:
Out of curiosity, what was the hacked version of Xp that you tried?  I've used an SP4 Vista look alike version that I can speak to.  If you can isolate the difference in drivers then you could slipstream just that missing part into a stable build of XP.
Go to full version
