Main > Everything Else
Cheap wired 360/PC controllers... under $11 at Amazon
<< < (2/2)
Well Fed Games:
I was thinking, in the project I would like to use them for, I only need 10 inputs per player (2 8way joys, start, coin), so with d-pad, face buttons, and start/back, I should be ok.... As far as hacking them, can I just ignore the triggers entirely or will they still be a problem?
Good to know that folks should pass if they have plans for the triggers!  :cheers:
If nothing else I will have a couple cheap (if extraordinarily ugly) pads for PC gaming...
--- Quote from: HaRuMaN on September 23, 2011, 09:41:21 am ---Good luck.  Hacking the triggers on those things SUCK.  There's a reason I don't touch them anymore.
HaRuMaN:
Oh yeah, you can ignore the triggers, no problem.
All the other stuff, including RB and LB, are easy to hack.  It's just the triggers that are a PITA.
Well Fed Games:
--- Quote from: HaRuMaN on September 23, 2011, 10:19:49 am ---Oh yeah, you can ignore the triggers, no problem.
Sweet! Thanks for the info! :applaud:
Navigation
[0] Message Index
[*] Previous page
Go to full version
