Author Topic: Help ID this coin door...  (Read 3468 times)
jekbrown
  • Last login:March 15, 2018, 12:18:58 am
« on: August 31, 2011, 12:20:22 pm »
Hey gang.  I've recently purchased an old over/under style coin door from a member of this site and was wondering if anyone here could tell me anything about it.  What game, or games, it might have been used on originally...what type of coin mechs they use, or anything else.  It's going to end up being used on my first MAME cab and I like ultra-detailed writeups...so if you know anything at all about this type of door, I'd appreciate it if you could pass on the info.  :)  If the guy who assembled these in Timbuktu only had one leg, and you know it for a fact, I'd like to know it too.   ;)
Anyway, all I know from messing with it is that it has steel main doors and the little reject coin doors are steel also.  It has a cast aluminum frame, reject coin button housing and the frame around where the coin drops down is cast AL also.  It has Atari coin-reject buttons.
closer up of the coin mechs...
Inside the top door, next to the coin mechs, is a small black sticker that says "Coin Controls Royton Oldham England Checked" on it.  The main door hinges are spot welded to the doors themselves, but attach to the frame with screws.
Can't think of anything else I can add that might help ID the beast.  So....whaddya think?
jessybr
  • Last login:December 25, 2016, 05:54:07 am
Re: Help ID this coin door...
« Reply #1 on: August 31, 2011, 01:14:05 pm »
hi looks like a door from a taito machine  special criminal investigation or chase hq i think
greetzz
jekbrown
« Reply #2 on: August 31, 2011, 01:47:51 pm »
oh cool!  If I might ask, what features identify it as such?   ???
It does look like the one in this not-so-good pic from klov...
...and this one too...
Alternatively, it also looks like one off of Star Wars...
which is from Atari.   ???  If it's from a Taito game and not an Atari game, what's the tip off?
« Last Edit: August 31, 2011, 01:52:47 pm by jekbrown »
Kevin Mullins
    • Me on Myspace
« Reply #3 on: August 31, 2011, 02:30:32 pm »
That is about as generic of a Coin Controls style coin door as they come. Used on many,many different games by many different manufacturers.
  • Last login:March 21, 2024, 08:20:28 am
« Reply #4 on: August 31, 2011, 02:41:08 pm »
Yep...very standard. The only thing you probably have to go off of is the Atari logo.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #5 on: August 31, 2011, 03:05:16 pm »
Yea...its super common. We called these types "over/under" coin doors.....
jekbrown
« Reply #6 on: August 31, 2011, 04:05:56 pm »
well that's no fun!  ;)
Thanks for the info guys.  I suppose it's good news that it's an ultra-common type, if I need any parts, they shouldn't be hard to find...
TopJimmyCooks
« Reply #7 on: August 31, 2011, 04:36:07 pm »
I just gave away one of those in good condition, but it had plastic loonie mechs.  Had the coin bucket, though.  They're easy to come by.
boardjunkie
« Reply #8 on: August 31, 2011, 05:01:28 pm »
Nothing wrong with the brownish/yellow plastic mechs. We actually had less trouble with those than the metal "Coin Mechanisms" ones. Dirty? Wash 'em in the sink with a brush and dish soap.....
« Reply #9 on: August 31, 2011, 05:34:43 pm »
Then strip the door metal with a Wire-wheel in your drill chuck, and repaint with hammered black. Or you can get it sandblasted if you have access to that resource. Either way, these coin doors/mechs aren't hard to get up to tip-top shape. Working too.
AlienInferno
  • Last login:April 28, 2024, 04:10:07 pm
« Reply #10 on: August 31, 2011, 05:41:37 pm »
I've got an over/under coin controls door.  Slightly different design on the door itself but it's a good coin door.  If you look in my sig at my build thread there are photos of it before, after it was stripped of paint, and after it was painted.  Like stated above they are very easy to get in tip-top shape.
Kevin Mullins
    • Me on Myspace
« Reply #11 on: August 31, 2011, 06:22:03 pm »
But the metal ones are cool-er .... Just because. :)
Seriously though, the plastic ones are easier to maintain and have less problems. Like you said, a good soapy wash is usually all they need.
eds1275
  • Last login:May 03, 2024, 12:05:34 pm
  • Rock and Roll!
« Reply #12 on: August 31, 2011, 06:35:14 pm »
Very similar to my mech - it's very easy to screw in some microswitches behind the coin return thingy to register a coin when the reject is pressed. I wired it up with the coin slot microswitch as well so either gets you a "credit".
jekbrown
« Reply #13 on: September 01, 2011, 01:00:48 pm »
Good idea on the microswitch, I might have to try that.
You guys say 'clean the plastic ones with soap/water!'....but what do you clean the metal ones with?  blast'em in brake cleaner or something?
Also, I think I'm missing a reject coin button return spring.  Is this the kind of thing you can find in the hardware section of a good hardware store, or cheap online or...?
compute
  • Last login:February 26, 2018, 05:33:36 pm
« Reply #14 on: September 01, 2011, 10:54:41 pm »
Thanks for posting the microswitch pic, eds.  I'm still debating how i want my gameroom to run, but it's nice to see an actual picture instead of just a description.
On a side note, both of my cabs have O/U coin doors.  One is early 80's Midway and the other is from a mid-90's dart machine (I think).  There are subtle differences.  That said, it looks more like the later one than the earlier one.  The differences may just be due to the operator, though.
boardjunkie
« Reply #15 on: September 02, 2011, 10:56:44 pm »
Midway never used over-under doors...at least not in the golden years.
compute
