Author Topic: Joystick's Right Direction Problems..  (Read 1620 times)
Lowell45
  • Last login:January 17, 2017, 11:12:30 pm
« on: August 25, 2011, 11:57:48 pm »
So I just finished my first cabinet and was ready to celebrate  :cheers: when I discovered that the Player 2 joystick's right direction has a problem.  It seems like it fires only when i release the right direction of the joystick.  So for example when playing mortal kombat: If I am player two and i want to move backwards and i move the joystick to the right, it does nothing until i release the joystick.  I checked the wiring and double checked the wiring and they are all wired to NO and GRD properly.  My joysticks and controls are running thru an IPAC4. I hooked a seperate usb keyboard to the computer and the Player 2's right direction works fine when using the keyboard.  All other joysticks work properly it is just player 2 that is messed up.  Could this be a problem with the IPAC? Has any1 else had this problem? Any help or suggestions would be greatly appreciated! Thanks!
  • Last login:March 21, 2024, 08:20:28 am
Re: Joystick's Right Direction Problems..
« Reply #1 on: August 26, 2011, 12:21:34 am »
Ohh, I hate that feeling when you think everything is done....then something comes up and ruins it all.  :angry:
I'd start simple, it could easily be that the switch is bad. Try connecting a different switch to the 2nd player right. Hopefully that switch will work fine, and you will know you just need to fix or replace the dud switch on your joystick.
If it does turn out to be the ipac4, then i am guessing you have at least a couple unused slots....maybe you could just wire the joystick right control to something like player 4, button 8...and then remap your emulators to the new control.
wweumina
  • Last login:August 30, 2022, 04:56:31 am
« Reply #2 on: August 26, 2011, 07:28:38 am »
Check your grounds, check you have wired to 'normally open' and not 'normally closed' and make sure it isn't the key that is configured to be the 'switch' key for the ipac. The last is probably the most likely.
HungryDave
  • Last login:May 27, 2012, 11:44:20 pm
« Reply #3 on: August 26, 2011, 08:21:27 am »
You're using an IPAC. Is the button set to be one of the IPAC shift buttons? They only 'fire' when released.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #4 on: August 26, 2011, 10:21:34 am »
The switch is wired wrong. You have the N.C. terminal wired in instead of the N.O. Switch it to the other one....
Lowell45
« Reply #5 on: August 26, 2011, 08:56:28 pm »
nope they are all wired correctly.  i turned off all the shift functions for the ipac, but when i try to program it i get a "Timeout" error.  i feel like throwin this damn ipac out the window
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
« Reply #6 on: August 26, 2011, 10:27:52 pm »
what if you try swapping out the switch just to eliminate the switch as a the problem.
Though it does sound like a shift key issue.
being that its an ipac 4, do you have a spare point to bring that switch to?
Lowell45
« Reply #7 on: August 27, 2011, 05:01:53 am »
i swapped out the switch with a new one and i still get the same problem..i was hoping it would just be a bum switch but it wasnt  :angry: and i do have empty slots in "SW7" and "SW8" if thats what u are asking?
mgb
  • North East, US
« Reply #8 on: August 27, 2011, 03:49:41 pm »
I would move that point over to one of the empty positions and see what happens
wweumina
« Reply #9 on: August 28, 2011, 07:20:40 am »
I believe the shift key on the ipac responds to the on_button_up command so that is almost certainly it.
mgb
  • North East, US
« Reply #10 on: August 28, 2011, 09:29:44 am »
pm sent
Lowell45
« Reply #11 on: September 04, 2011, 05:49:59 pm »
i finally got the ipac to work. had to buy a usb cable and hook it up via usb instead of ps2, this would allow me to program it without getting the "Timeout" message i was getting. also you guys were right, the button i had programmed as the right direction on the joystick was also programmed as a default shift function.  Thanks to everyone for all your replies and help!!!
