Author Topic: Popsicle drizzel and stuck buttons  (Read 2089 times)
rackoon
  • Last login:July 28, 2023, 02:29:36 pm
  • I EAT PENCILS!
« on: August 19, 2011, 08:10:26 pm »
Well, like the title says, I walked in to my office to find my 5 year old daughter playing bubble trouble with a Popsicle resting on the cp and sickey Popsicle juice all over her mouth hands and arms. Needless to say the cp was covered with sticky stuff and now my buttons are all stuck. :hissy:
How do I take these things apart to clean them? :dunno
 They are the standard concave happs buttons.
They treated me like an animal and that's what I became.
Re: Popsicle drizzel and stuck buttons
« Reply #1 on: August 19, 2011, 08:12:30 pm »
Push the plunger feet in towards the center of the button and push them through the holes.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #2 on: August 19, 2011, 10:04:04 pm »
The dishwasher works really well too once they are apart.   :cheers:
ed12
« Reply #3 on: August 19, 2011, 10:34:24 pm »
Hi
as a rule i just take them apart and either warm-water-soap/dry and or soak them then scrub them off with a tooth brush..
then hand dry them
but dishwasher is just as handy
ed
mgb
  • Last login:February 21, 2024, 06:18:13 pm
  • North East, US
« Reply #4 on: August 19, 2011, 11:14:08 pm »
And send her to her room
  • Last login:March 21, 2024, 08:20:28 am
« Reply #5 on: August 19, 2011, 11:19:07 pm »
another vote for dish soap and toothbrush....i don't like to put small things in my dishwasher because they can move and drop on the heat element, but if you got one of those small item compartments in your dishwasher silverware area, that would probably work great.
migraineman
  • Last login:July 01, 2016, 02:56:35 pm
« Reply #6 on: August 20, 2011, 09:39:33 am »
I'll expand on the disassembly instructions a bit, as it isn't always obvious.
Remove the microswitch from the button - gently pull the long retention-pin tab away from the switch, then rotate the switch 90 degrees to extract it.  Remove the button assembly from the control panel.  Depress the button.  You should see two tabs extend from the bottom of the button.  Squeeze the tabs together and push them back into the button housing.  Withdraw the plunger from the top of the housing.
Dish soap and warm water should be your cleaning agents of choice.  Harsher stuff may attack the plastic.
popsicle
  • Last login:April 19, 2024, 06:25:52 pm
« Reply #7 on: August 21, 2011, 04:37:28 pm »
What the hell is a popsicle?
rackoon
  • I EAT PENCILS!
« Reply #8 on: August 23, 2011, 02:04:56 am »
Thanks for the reply guys. I got them apart and scrubbed them with dish soap ;D
They work pretty good now :applaud:
I was worried about pushing those little feet in at first, but it turned out to be a piece of cake.
A POPSICLE IS A FROZEN TREAT IN THE SHAPE OF A GRAIN HAVESTING TOOL. IT ORIGINATED IN RUSSIA AROUND 1930, ALONG WITH THE LESSER KNOWN HAMMERPOP. THEY WERE BOTH LATER BANNED AFTER THEY WERE USED AS WEAPONS BY A ANGRY MOB THAT STARTED BECAUSE GRAPE FLAVOR HAD RUN OUT. THOUSANDS WERE WOUNDED, AND EVEN MORE GOT SEVERLY STICKY :cry:
