Author Topic: Simpsons Bowling  (Read 2246 times)
chewie26
  • Last login:March 28, 2012, 03:08:21 pm
Simpsons Bowling
« on: August 19, 2011, 10:16:38 am »
Is anyone running Simpsons Bowling with the sound working correctly? I've tried searching here and it seems like the sound on the rom is just bad, however I came across a youtube video of a guy running it on mame and the sound was fine. Is there a certain version of the rom or version of mame that it runs correctly on? I have the GQ829 UAA rom.
thanks
Hoopz
  • Last login:February 09, 2024, 02:36:26 pm
  • Intellivision Rocks!
Re: Simpsons Bowling
« Reply #1 on: August 19, 2011, 10:37:12 am »
MAWS shows the sound emulation listed as imperfect.
http://maws.mameworld.info/maws/
chewie26
« Reply #2 on: August 19, 2011, 12:20:15 pm »
never saw that site before, thanks for the link. I'm going to check it a bunch of stuff on there.
This is the video I found. Mine doesn't play that background music. Should I download the rom again?
Hoopz
« Reply #3 on: August 19, 2011, 12:31:38 pm »
Here is the version info:
version added   .080u3
last change(s)   .109
If you have a version from .109 or higher, than there isn't a reason to download it again.  It won't change.  I'm running .94 so I can't help on the sound issue.    :dunno
chewie26
« Reply #4 on: August 19, 2011, 01:44:55 pm »
thanks for the info!
Haze
    • MAME Development Blog
« Reply #5 on: August 20, 2011, 12:26:08 pm »
It works best on a current version, in older versions it might fail / have bad sound.
you just have to follow the usual Konami initialization process.
Simpsons Bowling
To initialize the EEPROM, hold down test switch F2 and press reset F3 once. Do not let go of F2 until you see a message that says "Initializing EEPROM".
rapomstage3
  • Last login:March 20, 2012, 06:36:57 am
  • Finish Him!!
« Reply #6 on: August 23, 2011, 08:48:15 am »
My sound is stuttery but i just figure its the ram.
