Main > Main Forum
Is it okay to add caulking around bezel?
syph007:
Or just redo the plexi and use a router this time.
upper2bits:
--- Quote from: syph007 on August 08, 2011, 08:40:03 am ---Or just redo the plexi and use a router this time.
The sad part is I started to use a router but thought it was going to melt it so I switch to the circular saw. I think the plexi was $10 so it might be worth it. Can you sand it down, I would prefer to cut it but and make it fit snug in the cabinet.
cigardude:
--- Quote from: pinballjim on August 08, 2011, 10:04:19 am ---Personally I just use electrical tape around (or in front of) the edges. If you can handle a long strip of tape, you can get a nice finished look easily.
Do you have a pic that you can post?
syph007:
Router worked best for me. Clamp a board along the line you want to cut, and use a flush trim. You end up with a perfectly smooth almost polished edge.
mytymaus007:
--- Quote from: upper2bits on August 08, 2011, 05:50:22 am ---There are little chips marks around my plexi despite using 150 tooth blade. :angry: I was thinking of getting some black caulking and running a 1/4-1/2 bead around the entire bezel. Has anyone does this, does it look okay?
any pics
