Main > Main Forum
Mini-Pac Failed to Program
<< < (2/2)
GoobZiLLa2:
Still not working. I've tried different USB ports and different operating systems (XP, Vista, Win 7). And I ran it as administrator on each one. I've also tried every single board/connection set up in the options menu.
GoobZiLLa2:
Same deal on win2k
GoobZiLLa2:
Problem solved. I was accidentally given a minipac with a modified firmware version. I exchanged it for a regular one and all is well.
Blanka:
Some MiniPacs like the Uhid based one you posted should be programmed as if it is a iPac4 if I'm correct. I've a mail conversation with Andy somewhere, and I guess that was the solution.
AndyWarne:
--- Quote from: Blanka on August 10, 2011, 03:29:56 pm ---Some MiniPacs like the Uhid based one you posted should be programmed as if it is a iPac4 if I'm correct. I've a mail conversation with Andy somewhere, and I guess that was the solution.
Err no. No MiniPacs are programmed as I-PAC 4!
The OPs problem was actually an issue which Dreamarcades needed to rectify and did so.
Navigation
Message Index
Previous page
Go to full version
